Painted Calipers, valve cover, intake mainfold and more!
Old Nov 6, 2002 | 10:18 AM
ejj's Avatar
ejj
I had a little extra free time this week, and the beauty of working from home is that I don't really drive much, so I decided to rip the car up.
I installed new brake pads, hardware and lines. Also decided to paint the calipers, because the previous owner had painted them silver (which I hated) and they are starting to look really, bad:
http://www.ericj.org/maxima/img/silver_pf_caliper.jpg
http://www.ericj.org/maxima/img/silver_dr_caliper.jpg
While I was at it I decided to paint my valve cover (not spark plug cover), intake mainfold, radiator supports, FSTB brackets, and a few other things.
Naked engine:
http://www.ericj.org/maxima/img/novcim3.jpg
Finished calipers:
http://www.ericj.org/maxima/img/painted_df_caliper.jpg
http://www.ericj.org/maxima/img/painted_pf_cailper.jpg
http://www.ericj.org/maxima/img/painted_dr_caliper.jpg
http://www.ericj.org/maxima/img/pain...iper_wheel.jpg
Engine bay before: (FSTB is already off)
http://www.ericj.org/maxima/img/engine_before.jpg
Engine bay after:
http://www.ericj.org/maxima/img/painted_engine3.jpg
http://www.ericj.org/maxima/img/painted_engine.jpg
http://www.ericj.org/maxima/img/painted_engine2.jpg
Yes, the worlds most exciting color! BLACK!
Old Nov 6, 2002 | 11:23 AM
Toolrocks's Avatar
Very nice. I think it looks good black. I'm commited to blue so when I get my VI I think I'm gonna paint it blue and maybe leave the cover silver I'll have to see. SO, when you removed the valve cover I assumed you replaced the gasket - is it expensive and is that a hard task?
Old Nov 6, 2002 | 11:43 AM
1FSTMAX's Avatar
Nice job, I like it!
Old Nov 6, 2002 | 11:45 AM
redmaxpa007's Avatar
i SeE what you did therE
i am sure you used high temp paint and clear coat
Old Nov 6, 2002 | 11:57 AM
ejj's Avatar
ejj
Nah. The gasket was fine. Cleaned it with carb cleaner and used some Grey RTV sealent on the corners. All good, no leaks. Removing the valve cover is countless times easier than the intake manifold, so if you're going to tackle that, don't worry about the VC. Take off the coils, there are ten bolts (have to be loosened and tightened in sequence...its in the FSM and Haynes manual) and that's it. The wiring harness doesn't make lifting if off the easiest thing in the world, so I pulled it back to the side.
Old Nov 6, 2002 | 11:58 AM
ejj's Avatar
ejj
Of course, and high temp grey primer as well.
The paint was actcually flat black, but the clear coat make it shine slightly. I'm happy with the finished color/look.
Old Nov 6, 2002 | 12:52 PM
Kevincleff's Avatar
What a difference! looks good
Old Nov 6, 2002 | 01:30 PM
Nealoc187's Avatar
SLOW
I've never seen engine parts painted black before, it looks cool. Should have thrown a VI on there while you had the IM off
Old Nov 6, 2002 | 01:36 PM
ejj's Avatar
ejj
Yeah, I ran to the local autozone and they where all out of the VI's, and I didn't think I could live without my car (or drive a car without an intake mainfiold) for 6 weeks.
Other than that, I was all over that idea!
Old Nov 6, 2002 | 02:12 PM
96BLUMAX's Avatar
Haha, yeah my track auto doesn't carry them either. Maybe walmart though cause they have everything.
Old Nov 6, 2002 | 02:13 PM
SuDZ's Avatar
The one near me has too many that they are making it an overstock sale item.
SuDZ
Old Nov 6, 2002 | 02:22 PM
happyricefob's Avatar
V^___^V
looks clean~~ i like it
Old Nov 6, 2002 | 02:41 PM
killamaxima's Avatar
look good so how long did it take to do everything...
Old Nov 6, 2002 | 02:52 PM
ejj's Avatar
ejj
A long time, but by choice.
I put the car up on stands Monday morning and took off calipers, brackets, pads, etc. Then I changed the brake lines.
A few hours later I took of the valve cover, and then put it back on. I realized that I didn't want it off when I was working on the intake manifold. Got the IM and VC off in about an hour and a half.
Then for the rest of the evening I painted. Because it was cold it took a while. From 4pm until 10pm to do 2 coats of primer, 3 color coats, 1 wet color coat and 2 clear coats.
Tuesday I put everything back on.
Today I bled the brakes, put the wheels back on, put the car back down then hunted down a vaccume leak. I didn't get a hose clamp back on right.
For sure doing all this is a two day job, just to let the paint properly dry. I just took my time because I had to get some real work done.
Old Nov 6, 2002 | 03:06 PM
meccanoble's Avatar
Sports Button FTW
that's the first time i ever saw the engine naked like that...looks real ugly but wow u did a great job
Old Nov 6, 2002 | 03:35 PM
ejj's Avatar
ejj
http://www.ericj.org/maxima/img/novcim1.jpg
http://www.ericj.org/maxima/img/novcim2.jpg
http://www.ericj.org/maxima/img/novcim4.jpg
http://www.ericj.org/maxima/img/novcim5.jpg
http://www.ericj.org/maxima/img/left_valves.jpg
Old Nov 6, 2002 | 04:27 PM
xHypex's Avatar
Paint your caps and add a VI and you'll be set.
-hype
Old Nov 6, 2002 | 05:35 PM
maximaah's Avatar
Re: Painted Calipers, valve cover, intake mainfold and more!
I had a little extra free time this week, and the beauty of working from home is that I don't really drive much, so I decided to rip the car up....
Your sig.... Are you running Z rims on front?
Old Nov 6, 2002 | 05:56 PM
ejj's Avatar
ejj
Re: Re: Painted Calipers, valve cover, intake mainfold and more!
Yeah. That picture was at my local track, and I have drag radials mounted on Z rims. They are for sale.
Old Nov 6, 2002 | 06:03 PM
ejj's Avatar
ejj
-hype
Yeah, next I have to do something about the spark plug cover. I'm thinking a gunmetal/black combo. When I do I'll paint the caps as well.
VI is down the road, but coming for sure!
Old Nov 6, 2002 | 06:20 PM
JPMax's Avatar
What's next!?..
Need to clean the rest of the hoses and pipes now to match.
Old Nov 6, 2002 | 06:23 PM
ejj's Avatar
ejj
To much work for a car that's going to be driven every day in the winter.
mvm062
Nov 30, 2020 09:00 AM
tgreen
Oct 18, 2015 06:18 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
tardrex
Sep 11, 2015 07:35 PM
