Piaa Blubs anyone melt harness
Old Nov 11, 2002 | 04:24 PM
RI-Max's Avatar
i have heard that when peeps from the org/ brother have melted thier harnesses. but u can upgrade the harness right, 2 a higher watt. casue i was thinking of getting piaa bulb casue my blubs are going bad (highbeam light comes on).but im scared of melting my harness too.
jeff
Old Nov 11, 2002 | 04:32 PM
JSClark's Avatar
Re: Piaa Blubs anyone melt harness
jeff
I have the PIAA Xtreme White bulbs, have been running them for a couple weeks now, no melted harnesses here.....
I think its if you have something brighter, like a 5000K+ HID bulb or something, not really sure...
Old Nov 11, 2002 | 09:31 PM
krzymax's Avatar
Maxima owner since 2000
my driver side fog light harness isn't working. i'm not sure if it's melted. the bulb still works fine, but the wire is not. i don't know how to change it.
Old Nov 11, 2002 | 10:45 PM
JPMax's Avatar
What's next!?..
jeff
If the wattage of the bulb is like 100w/80w then you should get the upgraded harness. www.suvlights.com
Normal wattage is 65w/45w I believe.
Old Nov 11, 2002 | 10:51 PM
JPMax's Avatar
What's next!?..
Hmm. I know Nissan sells replacement connectors for the headlight harness. Basically requires cuting the old connector off and connecting the new one on by whatever means you choose. (ie. soldering, strip and twist, posilock connectors, butt-end connectors, etc.)
You may want to check with your local dealer or talk to Ken at www.jerryromenissan.com to see if they have replacement connectors for the fog lights.
Old Nov 12, 2002 | 05:04 AM
ThurzNite's Avatar
no, piaa bulbs won't melt anything cuz they're stock wattage (which makes me wonder why people think they're so good?) They will just die out pretty quick, from what I hear.
Why would HID melt your wire harness? They're only 35watts each.
If you do a search, some members claim that instead of buying another harness, you could just add another wire to the ground and connect it to the chassis. I dunno the physics of that one. I also don't know the physics on why you would need an upgraded harness if the base of the bulb was made well (prevents heat from going backwards towards the harness. I think most harnesses melt cuz the contacts are dirty.
Jae
Old Nov 12, 2002 | 06:00 AM
flyer's Avatar
or may be it's the bulb that's fused, do you have u'r old bulbs that u can put back in and test?
PIAA's do have a tendencey of fusing sooner than others.
Old Nov 12, 2002 | 06:37 AM
RI-Max's Avatar
i think im just going to stay with factory blubs thanx guys
Fbana41
Aug 29, 2016 12:18 PM
doctorpullit
Mar 29, 2016 11:08 AM
magiconthetire
Oct 26, 2015 09:03 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
