Code 0115
Old Nov 12, 2002 | 05:21 AM
RI-Max's Avatar
Code 0115
i just got this code. its the rear bank and i think its a vacumm leak cause i got a whislte sound before. any ideas? before that i got a coolant temp sensor code but just cleared it. was that wrong or should i replace it. the car runs fine tho.
Old Nov 12, 2002 | 05:25 AM
Jamsan's Avatar
DTC 0115
Diagnostic Trouble Code 0115 indicates a problem with the fuel management system on the right cylinder bank.
The right bank is also called the rear bank. It is cylinders 1,3,5.
The Front Heated Oxygen Sensor for the right bank sent signals to the Engine Control Module indicating an
excessively lean fuel mixture. The ECM attempted to correct this problem by directing the fuel injectors to
supply more gasoline. Further signals from the Oxygen Sensor indicate that the attempt to correct the lean
mixture condition was unsuccessful, and the fuel mixture continues to be too lean.
Possible causes include ...
- Intake air leaks
- Defective Front Heated Oxygen Sensor
- Fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow Sensor
Old Nov 12, 2002 | 06:35 AM
RI-Max's Avatar
thanx jamsam
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
