Rear Brakes mushy and soft after change
Old Nov 16, 2002 | 08:03 PM
iansw's Avatar
Today, I installed Axis Pads on my rear discs.
I used the proper piston tool, brake quiet, and everything seemed to go well.
The one thing I did not do, however, was bleed the brakes.
Now my brakes are VERY mushy - I have to practically floor the pedal to get any good response. My E-Brake seems to work, but I still have to lift it up almost all the way to get it to work well. - So this tells me the rears are working, just not well.
Is this caused by air in the brake system, or is there something else I missed?
I did a search, and didn't find much....
Thanks!
Old Nov 16, 2002 | 08:17 PM
deezo's Avatar
There is air in the system. Try rebleeding them if you have already.
Old Nov 16, 2002 | 08:24 PM
KLoWnPR109's Avatar
bleed them and all your troubles will be gone
Old Nov 16, 2002 | 09:11 PM
mtrai760's Avatar
'Trynna' is not a word
You have to bleem them Ian. Even though it says it's not required if you don't disconnect the lines... I had the same problem when I changed my front brake pads, and I had to bleed them...
BTW, I think Jeff has some cool tool for bleeding brakes, you might want to ask him...
Old Nov 17, 2002 | 01:21 PM
MAXIN's Avatar
Which jeff? What tool?
Old Nov 17, 2002 | 06:56 PM
iansw's Avatar
It's this hommade thing that lets you bleed and flush your brake system with only one person.
Anyway, brakes have been bled - MUCH better!
Man that was easy!
IanS
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
