Alignment with conversion
Old Nov 21, 2002 | 02:31 PM
96BLUMAX's Avatar
Will do the 5speed conversion require me to get another alignment or will it not affect my alignment?
Old Nov 21, 2002 | 02:36 PM
SuDZ's Avatar
Re: Alignment with conversion
People dont need it after a clutch swap, and you pretty much remove the axles and tranny the same way for that. So I would say No.
SuDZ
Old Nov 21, 2002 | 02:39 PM
96BLUMAX's Avatar
Thanks, just making sure i wont knock my camber out or something.
Old Nov 21, 2002 | 02:52 PM
mtrai760's Avatar
'Trynna' is not a word
Actually, yes you should get an alignment, since you are removing part of the suspension (lower bolts), replacing the axles, etc, I would strongly recommend it...
Old Nov 21, 2002 | 03:42 PM
meccanoble's Avatar
Sports Button FTW
it makes sense u might need it but i never got it with my old car and never had a problem with alignment, steering, or driving in general...neither has everyone else i know that has done conversion...i wouldn't get it done
Old Nov 22, 2002 | 05:49 AM
njmaxseltd's Avatar
If you remove the strut to do the tranny swap, then you need to have the alignment set again.
Old Nov 22, 2002 | 08:57 AM
Stephen Max's Avatar
This comes up quite often and I'm puzzled with the responses. The FSM says that alignment is preset at the factory, and the use of close fitting shoulder bolts at the struts prevents any gross misalignment when you remove the bolts and reinstall them. There isn't even any provision for making alignment changes, unless you get aftermarket camber plates.
My personal experience is I've never needed an alignment done after removing the struts, and I've had them out three times. The car tracks exactly the same (i.e. straight ahead) before and after every time.
Old Nov 22, 2002 | 09:04 AM
mtrai760's Avatar
All I know is my alignment was close, but slightly out of spec after the conversion, and I know for a fact it was in before...
Old Nov 22, 2002 | 09:14 AM
How strange. Maybe there was enough clearance at the strut bolts so that you were slightly out of spec? I think I've heard of this happening before.
Calabar
Oct 5, 2015 09:57 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
kjlouis
Sep 14, 2015 11:22 AM
Hdnseek
Sep 9, 2015 05:55 AM
