checking the timeing
Old Nov 21, 2002 | 05:22 PM
Gary E's Avatar
How do I do this? The guy at the smog shop threw his inductor over the wires that plug into the coil (97 SE)does that work I thought it only worked on high voltage? I just have an old school timing light that has to have direct contace with the plug or wire.
Old Nov 21, 2002 | 06:06 PM
mzmtg's Avatar
Minister of Silly Walks
Why do you want to check it?
You can't adjust it.
Old Nov 21, 2002 | 06:28 PM
Gary E's Avatar
I figured as much, but just to make sure it was within specs. That was part of the reason it failed smog because the tech could not get a reading, he said that there was no spark at the #1 cyl, I checked and there is, so either he didn't know what he was doing or there was a loose conector or something???
Old Nov 21, 2002 | 08:04 PM
mtrai760's Avatar
'Trynna' is not a word
When I got my smog checked here in WA, they just through a rubber block on my hood that measured RPM... I don't see why he would have had trouble with your car, it shouldn't matter to him what your timing is anyway...
Old Nov 21, 2002 | 08:07 PM
SuDZ's Avatar
If there is no spark there it could be a coilpack. Check your ECU for errors
SuDZ
Old Nov 22, 2002 | 08:08 AM
Gary E's Avatar
there is spark, I think the tech was smoking crack, geesh you think he would have to know????
Old Nov 22, 2002 | 08:43 AM
mzmtg's Avatar
When you are looking under the hood, look at the big wire harness wrapped in tape that runs across the top of the injectors. On the front corner of the harness, on the passenger side, there is a little loop of wire sticking out of the harness. This is where you get an RPM signal with an inductive pickup. That's what it's for.
tsi6001
Oct 3, 2022 10:23 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
acw
Aug 13, 2015 12:50 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
