hard to shift...
hard to shift...
Lately, my tranny has been a little harder to shift than i remember. I find myself double clutching to help smooth it out. could it be my clutch or do i just need change my tranny oil?
Mike
Mike
Originally posted by iwannabmw
A leaky hydraulic system can cause difficult shifts as well.
Originally posted by A5295
i know this may sound stupid, but where are most of the leaks prevalent?
There are 2 spots I believe where the tranny would leak... or most commonly does. One is the driveaxel seal or the tranny position switch.
Tranny position switch:
http://forums.maxima.org/showthread....ght=PNP+Switch
Driveaxel Seal:
http://forums.maxima.org/showthread....ny+switch+leak
http://snow.prohosting.com/nprimex1/oil_leak/
Driveaxel Seal:
Driveaxel Seal:
I would say check the master cylinder level very carefully, if it goes down just a little over a few days or a week, then you might have a pin hole leak in the line. In this case look for sweating or moisture. Or you could bleed the line and see if you find any air bubbles.
I am having a similar problem and its just Pi**ing me off that I cant find out where the problem is. I replaced the master, rebuilt the slave, and the line is new.
Of course his problem could be something else, but I know thats my problem. Its like I cant push the clutch down far enough....I even adjusted the preload on the master cylinder.
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
