another suspension question...i have searched around too.
sup guys..i got another silly question about suspension..i couldnt find the info i needed with a search..so jsut thought id ask and hopefully someone would answer.. im have set of maxspeeds and agx's in the mail..should have them on by end of nov... question is should i get a rear sway bar too.. ive read some threads that say RSB doesnt do much after u dorp the car but does wonders when u leave it stock hieght..ive also read some that said the RSB actually takes away from handlign performance after a drop...so basically..im just debating whether or not to get a RSB with my maxspeeds on agx's..thanks alot..any replys will be appreciated..
Re: another suspension question...i have searched around too.
rear sway bars are a waste of cash...they dont make any difference to the car..what u should get is a front strut tower bar.......makes all the diff in the world.... rather than waste money on that put it to good use!afte ur suspension mods dont forget the WHEEL ALIGNMENT ONLY FRONTS CUZ MAX IS A 2 wheel align. car....dont be fall for all 4
98se-kybagx, eibachs, fstb, suspension
Re: Re: another suspension question...i have searched around too.
i took a ride in a lowered max w/rsb and i can tell you THAT is a world of a difference. you won't be disappointed.
lol...
hmm..thanks..ahha. 2 experienced maxima drivers gave me 2 completey diff answers....i already put on a fstb... didnt do much cept make the steering wheel a lil more responsive and tired moved less by themselves when i went over uneven road...handling wise..it didnt do jack. i judge the handling performance of my cars by how fast i can take this clover shaped freeway ramp.. my g20 took it at 50 before hearign tire squeal.. 240sx at liek 55.. max can only take it at 45..my friends wrx takes that sh** at 70..im amazed...ill try my setup w/o the rsb ..if im not content witht eh handlign ill get one later.. anyone have any bad expereicne with a RSB beign put on AFTER a drop....thanks againf or replyign guys..
Re: lol...
a slight difference. The RSB on the other hand, makes a WORLD of
difference. Play around with the mounting of position for the end
links to affect how much play it has for you. The RSB will help you
tremendously and definitely helps set the car to a more neutral
feeling from the heavy understeer. With the right throttle and wheel
inputs you can bring about easily controlled oversteer.
RSB was the last handling mod I put on and I'm sorry I waited so long
to get it done. If you want to push the limits of traction, get
great tires with a good-sized contact patch and toss on the RSB.
How about no?
The rear sway bar is the most noticable 15 min. bolt on suspension mod hands down. Dropped or not, you feel it big time.
A 4 wheel thrust alignemnt is the correct alighment for FWD cars. It should cost you about 50 bucks. The thrust angle assures the front wheels are tracking in the same tracks as the rear wheels. If thats not set correctly, your steering wheel will be off center.
APER5, Please get your facts straight before making posts.
I doubt you will be driving that hard in the snow to truely appreciate the RSB mod, i get alot of snow where im located and find my sway bars and lowered suspension is just a tease on the roads because you can really loose control if your in a fun mood. I'm a true believe that its a mental thing also, you drive harder with mods.
RSB is an excellent investment, it is an obvious improvement. Some people removed it when they installed their suspension. This was mostly because they wanted to save weight when running on straight track. If you have any form of curves on your daily commute the choice is simple.
Originally posted by speedemn
Is it better off to leave the installation of a RSB until the spring-time? I thought that the effects of a RSB in snow is not really as desireable.
Re: Re: Re: another suspension question...i have searched around too.
Originally posted by Dev
our cars have excess oversteer, and the RSB provides understeer to counteract it.
Aper5, are you being sarcastic? I hope so.
Re: Re: Re: Re: another suspension question...i have searched around too.
yo shut the **** up dont act like a wise ***
its a known fact max is a 2wheel alignment
why dont u go get a civic hatch herb max aint for u
Max noob
Try doing your clover ramp test with your Max that have the rsb and better rubbers, and you should increase that m/h. Also, the test that you did with the other cars are like comparing apples and oranges. WRX = all wheel drive, and G20 = Smaller and lighter car.
The mod that I did to my Max was the Stillen rsb, and it handled alot better in my oppinion. I also don't know how good or better is the brand of rsb.
FSTB worked good on my car. the steering was alot tighter and didn't go all over the road when i hit bumps. before the FSTB when i hit bumps and rough road i felt my car was all over and loosing control now its a lot better and easier to control, I think.
if maximas came stock with a rsb.. they would have sold a lot more cars. car and driver magazine would be ranting and raving about what a handler the family sedan is.. as for the fstb didn't make a bit of a diff, it's a good conversation piece and it compliments the look of the intake. maybe, if you want to fool yourself, you might feel a little difference on the highway changing lanes doing higher speeds with the fstb on. beside, they're only 12 bux nowadays.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
