Oil Pressure Switch Gone Bad
Old Dec 4, 2002 | 05:19 PM
tbannon's Avatar
My oil pressure switch is leaking. Is this something that is easy to replace. If so could somebody please let me know how to fix it. Thanks a lot
Old Dec 4, 2002 | 05:30 PM
RI-Max's Avatar
ya its easy just wait to change your oil and do it all at once(although u don't have to wait until then). if u search you'll find much stuff.
Old Dec 4, 2002 | 06:17 PM
MDubya
Re: Oil Pressure Switch Gone Bad
i changed mine last week..get something other than a OEM Nissan part. that was a deffect.Autozone:5.75 youll need a 1 1/16 inch socket to change it. its right above the drain plug..to easy
Old Dec 4, 2002 | 07:34 PM
1MAX2NV's Avatar
You can take it out and clean it up. Apply new thread sealant like Loctite or Teflon paste. You should be good to go.
Old Dec 4, 2002 | 07:43 PM
tbannon's Avatar
thanks for all the info
Old Dec 4, 2002 | 08:27 PM
1MAX2NV's Avatar
Oh...you need a big ole combination wrench. It's like one inch. I would just rent it because you will never use one that big. Unless you fix big rigs.
Old Dec 4, 2002 | 08:58 PM
Kashoggio's Avatar
i use bigger ones then that everyday and I dont work on big rigs
sdotcarter
Sep 2, 2015 09:53 PM
Lowered_a33
Sep 1, 2015 07:49 PM
FlaMark
25
Aug 28, 2015 10:15 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
