Starter Delay
When the key is turned to the start position in my '95 SE, a delay of approx 3 to 7 seconds occurs before the starter makes any noise. The battery and alternator were replaced 6 months ago. Any suggestions other than cleaning the starter terminal?
Thanks, |
Could be a number of problems, anywhere from claaing your starter terminal, to a bad ignition switch, start with the easiest, like you stated, starter terminal/ground.
Originally posted by NmexMAX Could be a number of problems, anywhere from claaing your starter terminal, to a bad ignition switch, start with the easiest, like you stated, starter terminal/ground. |
© 2024 MH Sub I, LLC dba Internet Brands
