error codes and hard starts
Old Dec 10, 2002 | 09:50 AM
monnster's Avatar
I am having some problems starting my car in this cold weather. The starter rotates but I need to step on the gas and keep cranking before it finally starts. A few days ago, my check engone light came on. I diagnosed it and found three error codes:
0304 - Knock Sensor
0407 - Crankshaft Position Sensor (Reference)
0707 - Rear Heated Oxygen Sensor
My car stutters a little bit sometimes during acceleration. After searching through this forum. I found out that this may be because of the knock sensor. And will replacing the rear oxygen sensor eliminate the hard starts? I am thinking of replacing the oxygen sensor first, and see how the car runs before replacing the other 2 sensors. The lowest price I found for the oxygen sensor is about 120 bucks from JeromeNissan. Is that a fair price?
If someone out there have experienced the same problems that I have and is willing to give me some edvice, I will greatly appreciate it. Thanks!
Old Dec 10, 2002 | 10:02 AM
Blaximazx's Avatar
Re: error codes and hard starts
0304 - Knock Sensor
I had the exact same problem, I would recommend replacing the crankshaft position sensor first and then the Oxygen sensor. With your engine running lean "i think" could have triggered a fault code with the knock sensor so there may be nothing wrong with it. Give it a try and let us know your results.
Old Dec 10, 2002 | 09:29 PM
monnster's Avatar
thanks for you advice....i will try changing the crankshaft position sensor first
Old Feb 13, 2003 | 06:38 PM
Saddam
if i were you, i would try cleaning the crankshaft sensor first...it gets clogged up, u know...
o2 sensor, cheap.
crankshaft sensor expensive.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
