Code 0505 (No Failure Recorded/Detected)
Old Dec 12, 2002 | 03:20 PM
nelaco's Avatar
Hello group. Just 2 days ago my "service engine soon" light came on steady. I checked the gas cap and under the hood for obvious stuff, but everything looked fine. The code I get is 0505, which means "No Failure Recorded/Detected" Do I have to do anything else, or should I just reset the light? Thank you for any help you can give me.
Nelson
'99 Maxima SE
Old Dec 12, 2002 | 03:28 PM
spiff56747's Avatar
Re: Code 0505 (No Failure Recorded/Detected)
reset it, and see if it comes on again
Old Dec 12, 2002 | 03:29 PM
Sprint's Avatar
just reset and go dawg...
Old Dec 12, 2002 | 03:34 PM
nelaco's Avatar
I just reset the light and so far it hasn't come back. Thank you for your help.
Old Dec 12, 2002 | 08:09 PM
nelaco's Avatar
OK, the light came back on. Now I get code 0102 Mass Air Flow Sensor. Up until I got the CEL on, the car was running a little rough at low RPMs. Now it runs fine...I guess the ECU is compensating for the problem. Should I just replace the MAF after making sure the connection is tight? Does anyone have the voltage values so I can test it with my voltmeter? Thanks again!
Nelson
'99 Maxima SE 55K
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
