Heat or cut springs??
I bought those dame Drop Zone spring on ebay and purchased all new Tokico Blues. After about 3 months of settleing the rear end has droped about 2" or maybe a bit more.. but as for the front i think its only droped about an inch.. i want to lower the front more to make it look even.. but i dont know wheather to cut a coil off or to simply heat one of them with a torch... have any of you heated or cut a coil before... how do you go about doing it... and i did run a search so there is no need to flame me...
Re: Heat or cut springs??
Are you saying that NONE of these threads answer your question?
http://forums.maxima.org/search.php?...der=descending
Not to rip on you, but that is often what happens when you are the innovator. You tried previously untested springs and are not satisfied. Kudos for the bravery, and thanks for the info on them. It just really sux that they did not give you the results that you were looking for. When I saw them on eBay I was a little suspicious because I had never heard of them on the org...now i am glad that I did not decide to be the first.
I would say cut them, or sell them on eBay and recoup your costs as best you can, then go w/ Maxspeeds, H&Rs, or B&Gs...
Well i guess it turns out im just going to ditch the springs come spring time. its either im getting groud control or just another set of spring that are org. Approved... So In other words Drop Zone Springs Suck.....
tarun900
19
Dec 20, 2021 06:57 PM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
