Still Missing?????HELP!!!!
Old Dec 17, 2002 | 01:36 PM
peter11's Avatar
I replace the plugs, air filter, oil, oil filter, fuel filter, and PCV valve. I also cleaned the throttle body. My car is still on the low end missing. What else can I do to get it to run right?
Old Dec 17, 2002 | 01:48 PM
MacGyver265's Avatar
Check the coil packs. Get a Haynes manual, that shold give you acceptable DC resistance specs and how to test the coil packs. If the coil packs are outside those specs, they need to be replaced.
Old Dec 17, 2002 | 01:50 PM
SonicDust187's Avatar
I will be at 90k miles on my max in a few months and would like to know how to replace the pcv valve.
Old Dec 17, 2002 | 02:10 PM
mzmtg's Avatar
Minister of Silly Walks
I would like you to learn how to read the FAQ.
Old Dec 17, 2002 | 03:44 PM
njmaxseltd's Avatar
Re: Still Missing?????HELP!!!!
Have you checked the ECU for the famous knock sensor code?
jmlee44
Oct 2, 2022 02:13 PM
conansriver
Nov 18, 2015 02:46 PM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
conansriver
Sep 16, 2015 12:17 PM
