Check engine light 0103, Coolant Temp. Sensor...
I just got off the phone with Courtesy and they say there is two of them. How do I tell which one is bad?
I was thinking of just ordering the cheaper one ($30).
BTW... Where are these located and yes I'm ordering a manual when I order it.
Thanks a million
Wizeguy
Thanks a million
Wizeguy
I was thinking of just ordering the cheaper one ($30). [/I]
Where are these located ...[/I]
... I'm ordering a manual ...[/I]
[Edited by Daniel B. Martin on 01-02-2001 at 12:46 PM]
Thanks a million
Wizeguy
Thanks a million
Wizeguy
There is usually a testing procedure in the FSM to tell if a sensor unit is good or bad. You usually have measure the voltage between two wires.
Thanks a million
Wizeguy
Thanks a million
Wizeguy
Ok I just called them back. This time no mention of there being two. The first guy must have thought I was looking for somthing else. Total of ~$30 shipped.
Thanks guys. Maxy appreciates it.
I wanted to follow up on this post.
It took me a total of 20 minutes to replace this part.
2 minutes to locate an appropriate sized hood support (read 2x4).
5 minutes to find the sensor. Btw... It on the battery side of the engine right off the side of the engine cover that everyone loves to paint red.
4 minutes to find my socket wrench. I really need to clean off that bench.
3 minutes to remove a portion of the air box.
2 minutes to remove and replace the sensor.
1 minute to reinstall the air box stuff.
Shut hood, start engine, crap lights still on! It must be something else! Damn....
Say bad words for 3 minutes.
Realize that I should try resetting the check engine light.
3 minutes to reset check engine light.
Start car, problem solved. Thanks a bunch guys.
Originally posted by rob
How did you reset the engine light?
the Check Engine light at Steve Cutchen's excellent MaxFAQs page:
http://web2.airmail.net/scutchen/max_faq/
This material is also covered the both the Chilton and Haynes manuals.
Glade for the info
I have had the 0103 code a couple of times, and the 0304 code. So I think my best aproach would be to replace Coolant Temp. Sensor first and see if that takes car of the the Knock Sensor code. Oh Wizeguy, was the 0103 code the only one that showed up, or did you have a 0304 code too?
the haynes' manual states you have to remove coolant before replacing the sensor, but if not necessary than that's grrreat since i recently flushed mines
It took me a total of 20 minutes to replace this part. Start car, problem solved. [/I]
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
