OIl Temp sensor mounting
Old Dec 25, 2002 | 08:16 PM
scoobs96gxe's Avatar
Ok, I have seen a few posts here about this, but no one has come up with a great answer.
Autometer does not make a fitting that will work. The Drain plug would be a great location, but the threads are M12/1.25
DOH!
So, basically you would need a 1/8 NPT to M12/1.25 fitting to make it work.
Hey, I would rather not Jimmy something into my oil pan.
Anyone got a suggestion?
Scoob
Old Dec 25, 2002 | 08:52 PM
96BLUMAX's Avatar
Trans temp manifold. Thats the best way.
Old Dec 25, 2002 | 09:05 PM
1MAX2NV's Avatar
You need to put the sender in the oil pan.
1. Drop the pan.
2. Drill a hole.
3. Braze/weld the bung to the pan.
4. Screw the sender into the bung.
5. Wire up the sender to the gauge.
Old Dec 25, 2002 | 09:19 PM
96BLUMAX's Avatar
O oops i read wrong. Thought it was for trans temp not oil temp. Yeah what 1max2nv said.
wyobbagy
Jan 3, 2023 12:03 PM
fastcarny
Oct 6, 2015 10:42 AM
97_GXE
Sep 15, 2015 06:47 AM
lux97Max
Sep 4, 2015 05:42 PM
sdotcarter
Sep 2, 2015 09:53 PM
