Fuel cut on a 95 SE
Old Jan 5, 2003 | 08:58 PM
Liquid_pjear's Avatar
Fuel cut on a 95 SE
I have a 95 SE 5-speed I got about a month ago, I enjoy it very much. However, the other night I was coming home really late and I was the only one on the bridge so I decided to punch it. I was cruising along enjoying the ride till about 120-125ish when it felt like I hit a brick wall. I was not near redline assuming tach is correct. I was told that the SE didn't have a fuel cut or any limit on top speed, was I misinformed or is there something else going on.
Old Jan 6, 2003 | 03:49 AM
Ramius83
If your car is a TRUE SE, then you shouldn't have this problem. What exactly are all your mods. Sometimes, depending on what you have, the car is already topping out at that time......
Old Jan 6, 2003 | 08:53 AM
MrEous's Avatar
^ Jeff™
Were you close to empty? Same thing happened to my '99 the other night. My cousin said his old Mustang ('96) did the same thing and that it was some sort of safety feature. I dunno...I filled up and it didn't do it again, so problem solved.
Old Jan 6, 2003 | 10:47 AM
Paonessa
i have a 95 se 5 speed and i took that sucker to around 130-135 before
Old Jan 6, 2003 | 12:30 PM
It is a TRUE SE and it is currently stock. It wasn't topping out, when you top out there is no sudden decelration like you hit a wall. I wasn't redlining it either. I had half a tank of premium as well.
Old Jan 6, 2003 | 01:36 PM
95CustomMaxima's Avatar
thats a speed limiter...but you shouldnt have that on a SE...my 95 SE doesnt have that...weird
Old Jan 6, 2003 | 03:52 PM
Nismo3112's Avatar
Custom User Title
Same thing happend to me too, i was on "E" and going to the gas station then i decided to rip it on the highway to get rid of my old gas....cut off at 110. Filled it up..went on to 135ish.
BTW i have a 99 too.
Old Jan 6, 2003 | 05:11 PM
Nealoc187's Avatar
SLOW
Perhaps your SE has a GXE ECU in it for one reason or another? Though 120-125 is a strange speed... the governor occurs about 116mph on GXEs.
Old Jan 6, 2003 | 05:12 PM
Paonessa
it's probably a safety feature so you don't run out of gas. it probably stops the camshafts from phasing if there isn't enough gas.
just a guess.
Old Jan 7, 2003 | 08:30 PM
Nismo3112's Avatar
Custom User Title
I had to have my ECU replaced, does anyone know what the replacement ECU's are programmed as? (SE GLE GXE)
jmlee44
Oct 2, 2022 02:13 PM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
