Brake groan?
Old Jan 8, 2003 | 09:44 PM
bluetentacle's Avatar
Brake groan?
I have a 98 Maxima. I bought it used last year and it's my first car. Due to my inexperience, I am not sure if I should be worried about this phenomenon that I've been noticing lately: whenever I came to a stop, and if the brake pedal was not pressed all the way down, a low, stuttered noise would be heard for a second or two coming from the front end of the vehicle. If I took care to press the brake pedal down firmly, however, there would be no such noise.
What's the deal? Should this be a concern?
Old Jan 8, 2003 | 09:47 PM
FLO_BOY's Avatar
Re: Brake groan?
Originally posted by bluetentacle
I have a 98 Maxima. I bought it used last year and it's my first car. Due to my inexperience, I am not sure if I should be worried about this phenomenon that I've been noticing lately: whenever I came to a stop, and the brake pedal is not pressed all the way down, a low, stuttered noise would be heard for a second or two coming from the front end of the vehicle. If I took care to press the brake pedal down firmly, however, there would be no such noise.
I had this -- your pads may be wearing out...
check 'em out if you can.
FLO_BOY
Old Jan 9, 2003 | 02:32 AM
Sprint's Avatar
its kinda like the brake squeal.. it means time to change your pads.. you aer hearing the metal part of the pad touching the rotor
http://www.turbomaxima.com/modules.p...iewlink&cid=24
Old Jan 9, 2003 | 06:10 AM
njmaxseltd's Avatar
Ahh the famous brake groan. It happens when you creap very slowly with your foot on the brake. Sort of like a deep moan with a slight deep frequency to it. Some pads are more prone then others to make this noise. A few guys including myself run Metal Master pads which seem to produce that groan very easily. A more organic pad should make that go away.
I don't think it should be of any concern, just make sure you have plenty of pad there.
Old Jan 9, 2003 | 09:59 AM
gaxima's Avatar
No problemo...
As long as it's a low pitched sound it should be fine. But when you get a high picthed "screeching" sound... means you need to change your pads.
Great choice with buying a Maxima.
-Robert
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
