alot of rear end vibrations
Old Jan 10, 2003 | 03:37 PM
Velcro's Avatar
I got a 97 maxima with 130k miles, just recently I've had alot of vibation from the rear, I got the tires balanced and the car aligned(should have seen the print out)and it seems to have helped a little but the vibration is still there, are those rear rotors suseptable to warpage?
Old Jan 10, 2003 | 06:16 PM
njmaxseltd's Avatar
Re: alot of rear end vibrations
You'd only feel that when you step on the brakes.
Old Jan 11, 2003 | 05:48 PM
Velcro's Avatar
Re: Re: alot of rear end vibrations
Is there any other reason, other than tire balance, that the back end would vibrate so much?
Old Jan 11, 2003 | 06:54 PM
njmaxseltd's Avatar
Bearings, shocks, worn bushings.
Old Jan 11, 2003 | 09:32 PM
bizz's Avatar
actually you might feel it even when the car is in motion when the rear breaks or front rotor are damaged.. if they are being cut into by the breaks or are damaged, the car will feel like its vibrateing, mostly while turning..
Old Jan 12, 2003 | 12:45 AM
Velcro's Avatar
that is a good theory I had replaced the brakes myself about a month ago, the shop that turned my rotors said they were fine, I doubted it but I put em back on anyway. the car does vibrate more when turning. thanks bizz
AcuraLegend
Sep 22, 2015 04:22 PM
JoshG
21
Sep 4, 2015 09:04 PM
wingsfan24
Aug 15, 2015 07:35 PM
Bruceharrison
Aug 9, 2015 07:56 AM
