What happened to my brakes?
Jan 12, 2003 | 11:46 PM
After a couple of hard stops in a row to see how much better my cross drilled setup worked the brakes felt mushy. I figured they had just faded so i wouldnt use them hard and they would go back to normal and it is only 20 degrees anyway. 10 minutes later no improvement the brakes are still very mushy and almost go to the floor. what is wrong and what do i need to do?, the rotors and pads look fine also why did this happen any input?
Jan 12, 2003 | 11:50 PM
new pads? maybe got air in them when you pushed the calipers back? Have you bled them?
Jae
Jan 13, 2003 | 12:04 AM
No this setup has been on my car for a while but i had never used them hard untill now and the brakes felt great before this.
Jan 13, 2003 | 06:04 AM
What kind of pads are you running? If you aren't running good pads, you've probably glazed them over.
Jan 15, 2003 | 06:21 AM
check your lines, get stainless steel brake lines.
Jan 16, 2003 | 12:54 AM
Quote:
have you changed the fliud recently? how many miles are on it?
