Suspension Guru's I need some help
Old Jan 15, 2003 | 07:15 AM
Kevin's Avatar
I am driving and everytime I make a extreme left turn ( as if I was doing a u-turn) I hear a knocking sound comming from the front right suspension. Exactly like a knocking, it's almost as if it happens when that side is fully compressed. any ideas?
Old Jan 15, 2003 | 07:38 AM
hacim105's Avatar
Re: Suspension Guru's I need some help
Are you sure it's a knock and not more like a dong. Or does it happen like a whole bunch of times like 3-5 times during the turn? If so you probably need to get a new strut bearing or repack the grease yourself. But it's kind of hard and irritating.
Old Jan 15, 2003 | 08:20 AM
Lime's Avatar
when driving in a straight line slowly you do not hear the noise?
Is it a clunking noise?
The strut bearings can cause noise, especially when the wheel is all the way over.... You can also check to see where your isolator is sitting at the bottom of the spring. If the isolator is over the end of the spring on the perch, noises occur.
Old Jan 15, 2003 | 08:58 AM
Canuck's Avatar
CV Joint?
Old Jan 15, 2003 | 09:01 AM
njmaxseltd's Avatar
Kevin you got all new strut components when we did your H&R/AGX install this past summer. I don't think it's got anything to do with the strut assembly.
You did have a creak from what we thought was the lower control arm. Perhaps that problem has now amplified.
Old Jan 15, 2003 | 09:03 AM
Kevin's Avatar
doesn't happen any other time except when I've got the wheel turned all the way and the suspension is compressed on the right side. don't hear it during regular driving. Strut bearing is brand new less then 6 months of use. it happen about 5 or so times, not really a clunking, sound more like someone knocking on a wooden door.
I would hate to have to take all of it apart but it sounds like that might be where this is going.
Old Jan 15, 2003 | 09:05 AM
Kevin's Avatar
Hey Tom,
The creak from the lower arm dissapeared about a couple of months after we did the suspension. This sound jsut recently started heppening. I agree with you that it's prboably not hte assembly. I'm thinking more like CV joint as Canuck said. what do you think?
Old Jan 15, 2003 | 09:35 AM
JAY25's Avatar
Hey Tom,
broke CV joint makes noises like that when you turn a vehicle. You can check the strut bearing that will make noise when you turn but also when you hit a small bump and last the control arm.
Old Jan 15, 2003 | 09:41 AM
ReddoG_Max's Avatar
At the bottom of the strut there is a 12mm bolt comming out pointing to the outside of the car. This bolt needs a plastic cap on the end of it. Sometimes when the car is turned hard that bolt hits metal and makes a large creeeek noise. I had this problem..put the plastic cap on that bolt..went away.
Will take a pic
Old Jan 15, 2003 | 10:08 AM
KWheelzSB's Avatar
Sounds like a bad CV joint to me.
Slightly worn CV Joint <-----------------------> Very worn CV Joint
Humming<------------------>Clicking<------------------>Knocking
Worn CV joint can cause a steering wheel shake at highway speeds, as well.
Old Jan 15, 2003 | 10:28 AM
njmaxseltd's Avatar
Hey Tom,
Kev, wasn't the right CV the one that fell apart when we did the install? You did get a new band put on right? That drive shaft was replaced just before we did the job if I remember correctly. Take a quick look and make sure the boot hasn't fallen off or split open. You'll see the grease all over the inside of the wheel if thats the case.
Does the knock happen when the car is moving, under accelleration or just coasting? CV's make a click click click under load when they go bad. Load meaning accelleration. Just turning while coasting usually will not cause the CV to make noise, so if your noise is happening without load on the CV it's probably related to that creak you had.
Stop by some time over the weekend and we'll do some quick trouble shooting. Do you still have my #? You could meet me at the body shop and we'll put the car up on the lift and look at it.
Just let me know....
Tom
Old Jan 15, 2003 | 10:40 AM
Lime's Avatar
Tom can I come use that lift?
Old Jan 15, 2003 | 11:32 AM
Kevin's Avatar
Tom,
Yeah I had the shop fix the band the week after we did the suspension. The knock only happens when I'm making a hard left turn ( almost like a fast u-turn). Doesn't happen at any other moment.
not during coasting or accell. Its not exactly a click either, definately like knocks. PM me your number and we'll get in touch.
Kevin
Tom
Old Jan 15, 2003 | 11:34 AM
sil SE's Avatar
i think i have a similar noise, actually im thinking i could be from my y pipe by the collectors for some reason.
but in any case, my noise sounds like somethings loose and knocking around , or a few marbles rolling in a container.
Old Jan 15, 2003 | 12:25 PM
Lime's Avatar
wheel bearing can also cause humming.
Old Jan 15, 2003 | 12:29 PM
njmaxseltd's Avatar
Erica my dear, you can use any of my tools.
Old Jan 15, 2003 | 12:42 PM
Eric L.'s Avatar
A knocking sound while turning is most likely due to a CV Joint, but usually those sound like "clack-clack-clack." A worn strut mount will also make knocking noises. I had the pleasure of having both these components fail on me simultaneously on my old VW, and it was a real headache figuring out where the noise came from.
Old Jan 15, 2003 | 03:43 PM
Velcro's Avatar
Sil SE thats your catalytic converter making the marble sound, it's shot.
Old Jan 16, 2003 | 04:47 AM
ReddoG_Max's Avatar
Check this small cap and make sure it is there. If not, when you turn hard it rubbing metal on metal. I had a loud noice before, this little cap took care of it.
Picture included for ya
Old Jan 16, 2003 | 08:46 AM
sil SE's Avatar
possible after ~65k?
its only on a left turn though
Old Mar 5, 2008 | 01:08 PM
hotimportnight9's Avatar
i have the same knocking noise but mines happens weh nim slowing down to park, it comes from the right side of the passenger side, what could it be?
Old Mar 5, 2008 | 03:58 PM
bigpulve+'s Avatar
Holy Zombie thread Batman......
No need to bump a 5 year old thread for that....
Old Mar 9, 2008 | 08:48 AM
Kevin's Avatar
holy cow! I forgot about this problem! for those tha are curious, mine ultimately ended up being an axle on the front right. sadly the car just sits now for most of the time, I dont have the heart to get rid of it.
Old Mar 9, 2008 | 01:08 PM
aznsap's Avatar
hey i actually have the same problem. i think i may have received a defective passenger side axle (purchased a remanufactured one).
is it a problem if i drive on it for a while, since i don't have time to replace it now?
Old Mar 9, 2008 | 08:34 PM
MrDicks95SE's Avatar
Offset Is Everything.
id get it done as soon as possible. you should be alright for the time being...
Old Mar 9, 2008 | 08:50 PM
mindlessoath's Avatar
i have this issue with h&r lowering springs and tokico blues. i belive its the springs because it doesnt happen with any other brand.
Old Mar 10, 2008 | 04:19 PM
vilmaxima's Avatar
I got the same problem with the left turns, I replaced both axles, all new strut/spring crap. Noise is still there, I even did that barber style vinyl wrap for the springs like in the suspension stickies, still makes the same noise not as bad, could this be from lowering the car? Ive had my car dropped on eibach pro kits with illuminas for about two years and the noisse just started recently.
Old Mar 11, 2008 | 10:07 PM
aznsap's Avatar
so apparently, it may not be the axle, according to what some people here are saying. im lowered on tein s techs and tokico illuminas, but i didn't notice this clicking until a little bit after changing the axle.
i've checked the boots and they aren't torn, so what could be causing the clicking?
Old Mar 13, 2008 | 11:10 AM
i remember an old post about this. you have to see if the springs are hitting something when you do this. have someone look at them when your doing the turn. they will be able to see it, but its a tight fit to seeit.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
