need help locating EVAP valve...FAST!!!
Old Jan 16, 2003 | 08:30 AM
mb1's Avatar
mb1
Is it the longitudinaly placed cylinder looking thing, attached by 2 bolts to the front part of the black box, located on the rear left side of the car?
Old Jan 16, 2003 | 09:02 AM
marc98se5's Avatar
Re: need help locating EVAP valve...FAST!!!
Yep that is it, you will probably will need to change that "black box" (Canister) too. I had the error light come on on the dash, and found to be that. I think the parts are around 70 bucks for both. Unfortantely when I took the error code reading I didn't know what it was and brought it to the dealer. Well they replaced these two parts and charged me $160 labor. Sucks cause if i knew this would have changed it myself Good luck!!
Old Jan 16, 2003 | 09:11 AM
mb1's Avatar
mb1
Re: Re: need help locating EVAP valve...FAST!!!
Ok thanks. I got impatient, and removed the valve already.
What is the cleaning process that everyone used to get rid of the code? I just sprayed carb clener in there, and WD40.
Old Jan 16, 2003 | 09:13 AM
marc98se5's Avatar
Re: Re: Re: need help locating EVAP valve...FAST!!!
Sorry can't help you there about cleaning, dunno. But to remove the Service Engine Soon code, there is a sticky at the top. Pretty easy to do
Old Jan 16, 2003 | 10:30 AM
Swafford98's Avatar
i tried and it didnt work.
what is your actual code??
i replaced the sensor you are talking about and the code came back.
code 0111
Old Jan 16, 2003 | 10:45 AM
marc98se5's Avatar
Re: Re: Re: Re: need help locating EVAP valve...FAST!!!
code 0111
The code that I got was
0215 = EVAP canister vent control valve closed
Nissan replaced both the sensor and canister then reset the ecu
Old Jan 16, 2003 | 10:49 AM
mb1's Avatar
mb1
code 0111
0215
I sprayed it, and reset the ECU. We'll see in a couple of days if it worked.
my03maxima
Jul 28, 2024 07:40 AM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
