Rear Main Seal trouble! help.
Old Jan 17, 2003 | 03:51 PM
RI-Max's Avatar
how do i remove it??? theirs 3 blots (removed) now what??? i tried to put a screwdriver on the back of the retainer 2 pop it out. what im i doing wrong??? is that RTV silicone that stronge??
Old Jan 17, 2003 | 04:07 PM
Jeff92se's Avatar
I'm needing a caw
It's not that easy to remove. Screwdrivers aren't really the correct tool. They sell seal removers at tool places. The are curved and are designed to remove main seals, front seals etc.. I think they look like picks. You probably have to mangle up the seal pretty good to get it out w/o a seal tool. Just be DAMNED sure you don't damage the surfaces that the seal rides on or it will leak even w/ a new seal! Carefull when you put it back in. Straight! And note how far the seal is installed BEFORE you take out the old one.
Old Jan 17, 2003 | 04:37 PM
RI-Max's Avatar
u think u can get me a pic of what it looks like??? u think autozone would have one?to rent???
Old Jan 17, 2003 | 04:45 PM
Jeff92se's Avatar
I'm needing a caw
I haven't seen one in years but in general this is what came up searching
http://www.bradystools.com/oilsealpulsk.html
Old Jan 17, 2003 | 04:51 PM
RI-Max's Avatar
oo ok i have one of those i use it to take out axle seals i'll try that. i have to pull out the whole retainer seal-retainer.
Old Jan 17, 2003 | 05:14 PM
cbr2's Avatar
The seal has a metal inside... Put the screwdriver at an angle and you can hammer right into it. Then pop it off.
Old Jan 17, 2003 | 05:19 PM
RI-Max's Avatar
what about if i make a hole in the seal and get the oil puller in their and pull!!!!! we'll see 2morrow
Old Jan 17, 2003 | 06:57 PM
TILLEYS99's Avatar
Lives in a 11sec maxima
Re: Rear Main Seal trouble! help.
It has a pin (guide pins) on either side just pry with a screwdriver BTW the original sealant they use is very strong especially on the timing cover!
Old Jan 18, 2003 | 09:07 AM
RI-Max's Avatar
ok thanx guys i got the rear main off. put silicone on the retainer & install. flywheel in the clutch now wait for trans to be done at the trans shop down the street. i can't wait but i didn't change the pilot bearing cause i didn't have a tool. i bought one from snap on but it was too big . i hope i don't have problems in the long run. what would it do if i didn't replace it?
Old Jan 18, 2003 | 02:39 PM
RI-Max's Avatar
i just seen a lil rubber gasket on the retainer off the old one i don't think i put it in on the new one casue i didn't buy one.unless it came with the new one. anyone know? i just need help bleeding the clutch. need 2 peeps and thier only me
AcuraLegend
Oct 17, 2016 08:47 PM
Huttig2009
Sep 25, 2015 03:31 PM
AcuraLegend
Sep 22, 2015 04:22 PM
boomerbrian
Sep 2, 2015 03:46 PM
