Might do Red Clears tomorrow.
Old Jan 25, 2003 | 11:42 AM
markargente's Avatar
Tomorrow, i plan on doing my clear corners, rewiring fog lights, installing my new lights, and doing my red clears. i just had a quick question that i oculda probably found on a search but im in a rush... what tool would i cut the flourescent covering from home depot for my red clears ?
-Mark
Old Jan 25, 2003 | 11:51 AM
I30tMikeD's Avatar
Re: Might do Red Clears tomorrow.
-Mark
I used a box cutter. Just score it repeatedly. Many others use a dremel which would be ideal.
To fine tune the edges for a perfect fit, use sand paper or a metal file.
I also suggest using a little silicone sealent when resealing the housing. I will keep out any leaks.
Old Jan 25, 2003 | 01:46 PM
spiff56747's Avatar
if you don't have a dremel, buy one of those special flourescent light cover cutters.
You'll still have to heat the blade so that it melts right through the plastic, because it was made to use for straight cuts, not small curved ones, which is what you need.
I used a portable camping stove to heat the blade in my garage, it worked pretty well, but its time consuming.
Old Jan 27, 2003 | 08:34 AM
95maxima's Avatar
has anyone posted instructions on how to do a red/clear conversion?
Old Jan 27, 2003 | 08:58 AM
Sean97SE's Avatar
i used scissors........dont follow my example, my left lense recently popped out and is just pressed against the housing.
Apr 16, 2020 05:15 AM
bigfrank
Oct 1, 2015 12:51 PM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
