5spd Transmission problems --- Please Help
Old Jan 27, 2003 | 08:09 AM
nizmo's Avatar
The shifter is extremely stiff during cold starts and it stays that way untill the car reaches normal opearating temperatures. The same thing with the clutch. It seems like it doesnt spring back into its original position fast enough after I let go of it when I change gears. What do u guys think?? I'm thinkin master/slave cylinder .... any ideas??
Thanx
Nas
Old Jan 27, 2003 | 08:13 AM
iwannabmw's Avatar
Re: 5spd Transmission problems --- Please Help
Thanx
Nas
It's probably more because this winter is much colder than the last few. Shift slowly until everything is warmed up. A bad master and slave cylinder would also exhibit problems when warm as well.
Old Jan 27, 2003 | 08:15 AM
96BLUMAX's Avatar
Well the shifts could be cause its cold but maybe there is air in the hydraulic system causing the pedal to not return normally.
Old Jan 27, 2003 | 08:27 AM
nizmo's Avatar
hmmm so you guys are saying it is normal for the shifter to feel that stiff?? I dont recall this stuff happening last winter so I was kinda worried. Maybe the pedal thing is my imagination but I'll bleed out the system just to be on the safe side. Anyone else experiencing these kinds of problems??
btw thanx for ur input guys.
Old Jan 27, 2003 | 08:28 AM
ChiTown Max's Avatar
I wouldn't worry about it if it happens only when it's really cold, then goes away when the car warms up. Mine's been doing that for years, no problems. It's just the weather....
Old Jan 27, 2003 | 01:43 PM
jbreit's Avatar
a full synthetic will improve this some...it will also help that stubborn downshift to 1st while you are rolling yet. I Bought amsoil for mine...they make a gl4 specific gear oil, but i think their standard gear oil is compatible.
bleed the clutch slave cylinder....it take 5 minutes if you have two people...or one person if you have a vacuum bleeder.
Old Jan 27, 2003 | 02:01 PM
nizmo's Avatar
Yea I been thinkin bout goin Redline MT90 for a while now but dont got the doe rite now.
Thanx for all your help guys.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
