Clunking strut bearings
Old Jan 7, 2001 | 01:36 PM
mzmtg's Avatar
Minister of Silly Walks
My strut bearings have been clunking and popping for a while. They do this as I turn the wheel from lock to lock. I didnt think much of it, except now the bearings are so bad that it makes the car hard to align. has anyone else had this happen? How much did you pay to get them replaced?
Old Jan 7, 2001 | 01:50 PM
sinewave's Avatar
Strut bearings? Do you mean half-shaft CV joints? You can get remanufactured half-shafts for about $150 per side. You can do them yourself if you have right tools and enough ability to change your own struts.
Old Jan 7, 2001 | 01:55 PM
ny96max's Avatar
dont even remind me, i changed mine 2 times. The jack-a$$ who did my suspension never changed them for me when i had the car lowered. Then the driver side went bad after a month, then the passanger side another month after that. So maybe 6months later they both went again. I asked th guy who did the work what brand he was using, he told me some aftermarket brand. I was sooo pisssed and i had him change them both with OEM Nissan parts and they have been fine ever since.
Old Jan 7, 2001 | 02:26 PM
Eric L.'s Avatar
Sounds like CV joints to me. Check to see if you have cracked or leaking CV boots (grease will be all over them). Also, another possibility is worn upper strut mounts. This can also cause the characteristic chattering sound when turning, or at least it did on my old VW.
Old Jan 7, 2001 | 02:41 PM
mzmtg's Avatar
No, it's not CV joints. It's the upper strut bearings. How much do the OEM parts cost, ny96maxse??
Old Jan 7, 2001 | 03:03 PM
Daniel B. Martin's Avatar
A strut bearing noise will be heard as you crank the steering wheel from lock to lock while the car is stationary. A CV joint will make it's characteristic clicking or snapping noises only while the car is in motion.
Old Jan 7, 2001 | 06:44 PM
CFster's Avatar
I had the same problem with my muffler bearings. That was after I replaced the water pump on my old Beetle.
Old Jan 7, 2001 | 09:32 PM
dch95's Avatar
Old Jan 7, 2001 | 10:20 PM
MADMAN's Avatar
i have that same problem
When Im driving sometimes i turn the wheel left to right and i always heard this clunking noise. what is that
Old Jan 7, 2001 | 10:34 PM
dch95's Avatar
Re: i have that same problem
The bearing on your struts where it mounts to the frame/body. There is a bearing that allows your strut to turn left or right and it is probably wearing out. This involves removing the strut/spring assembly and using a spring compressor and taking off the strut mount/bearing assembly and replacing it.
Old Jan 7, 2001 | 11:30 PM
ny96max's Avatar
i honestly cant remmeber, its either $15 or $30 a side from Nissan. Im calling nissan tommorow about another part so i will find out for you how much they are a piece.
Old Jan 7, 2001 | 11:50 PM
Mike S.'s Avatar
Funny.......
I was posting about this noise for months....all summer long.....and NOBODY knew what it was Anyway....it seems to go away in cold weather....I haven't heard it since October. The dealer quoted me I think 319 parts and labor for both front bearing plates..och!
Old Jan 8, 2001 | 03:49 AM
CFster's Avatar
Re: ?????????????????????
Joking...
Old Jan 8, 2001 | 07:38 AM
JMX's Avatar
JMX
Re: Re: ?????????????????????
TRY TIGHTING THE STRUTS FROM THE TOP, AT THE SAME TIME TURN YOUR STEERING WHEEL, MAY TAKE TWO PEAPLE. The person who did mine probily did'nt know what he was doing in the first place, or inexperianceed
Old Jan 8, 2001 | 11:56 AM
dch95's Avatar
Joking...
OOPS! Sorry about that!
Old Jan 8, 2001 | 01:28 PM
ny96max's Avatar
my dealer gave me a quote for $15 a piece for the new bearings.
Old Jan 8, 2001 | 01:49 PM
dch95's Avatar
Strut Bearings
If you do it yourself you will already have the spring compressor, you might as well do them both.
Unclejunebug
Apr 2, 2016 05:42 AM
maxima-junky
Oct 7, 2015 06:13 PM
Andy29
Sep 29, 2015 05:32 AM
