Anyone with a VI running nitrous?
Old Feb 6, 2003 | 09:26 AM
xHypex's Avatar
I'm sure there's someone who has a VI and is also running nitrous.
All the talk of a JWT ECUs with a VI is making me want more power, but unfortunately being a '99 I'll never get an ECU. Since I am limited in my rpms (~6500), and I wouldn't want an ECU with nitrous anyway I'm starting to do more research.
Does anyone have a dyno with a VI and nitrous? I'm also open to other suggestions on alternative routes to take besides nitrous. I can't afford a turbo now, but maybe in the future.
-hype
Old Feb 6, 2003 | 10:37 AM
1MAX2NV's Avatar
Re: Anyone with a VI running nitrous?
Nitrous and VI should be a nice combo. You really don't have to worry about the torque loss in the lower RPM range because nitrous will make plenty. With nitrous and USDM manifold, I still get the same HP dip after 5K rpm.
-hype
Old Feb 6, 2003 | 11:18 AM
Ramius83
Re: Re: Anyone with a VI running nitrous?
Tony, what about the use of the MEVI with a wet kit, single fogger? Won't the fuel puddle when the "air chamber" is opened?
Old Feb 6, 2003 | 11:39 AM
xHypex's Avatar
Re: Re: Re: Anyone with a VI running nitrous?
I was curious about that too. It seems that in this case a dry kit might be the best option with a VI. I'm open to opinions, but the VI throws new variables into the mix.
-hype
Old Feb 6, 2003 | 11:41 AM
Jime's Avatar
Re: Re: Re: Re: Anyone with a VI running nitrous?
-hype
There are many Variable Intake Honda/Integra's using NX with excellent success.
I was told a year ago by many people on here I couldn't run a wet kit on the standard manifold.
There are still people saying it.
I would probably buy the MEVI but I haven't seen much improvement in acceleration to make me want to spend that much money.
Old Feb 6, 2003 | 11:50 AM
MardiGrasMax's Avatar
Re: Re: Re: Re: Re: Anyone with a VI running nitrous?
Kind sir, I will be switching to wet system. under 50hp, for this season, thank you for proving me wrong! I like the tunability of the wet much better.
Old Feb 6, 2003 | 11:57 AM
Jime's Avatar
Re: Re: Re: Re: Re: Re: Anyone with a VI running nitrous?
I wasn't referring to you Matt. But I did have quite a few folks say not to do it.
Actually I think you should stick with your present kit it will keep your times down. Last thing we need is your car going faster.
You will love the wet, much easier. I love simple.
I am working on a few things for this year but want to wait till the track opens before I make any noise about it being any better than what I have now.
Old Feb 6, 2003 | 12:06 PM
xHypex's Avatar
So, does the extra flow of the VI really effect the nitrous variables at all (fuel pressure, EGT, A/F, etc.)?
-hype
Old Feb 6, 2003 | 01:45 PM
I have run a 40 shot dry with 10psi and I did see a blip in the dyno chart but nothing bad.
Old Feb 6, 2003 | 07:19 PM
1MAX2NV's Avatar
I don't know. Nobody would know for sure until someone tries it. It won't be a problem with direct port since where the nozzles would be the butterfly.
Old Feb 6, 2003 | 07:58 PM
CoOlKidS1979's Avatar
I was gonna run DPI on my mevi, expect that I didnt trust myself to tap the manifold and bend the tubing neatly so I brought it a shop. After telling the owner exactly what I wanted he went and tapped the underside of the manifold, he then told me that he went to nissan and got "schematics" and that it would fit fine. Of course the foggers where hitting on the rear valve cover and injectors if I remeber correctly. I never did get the nitrous running, I ended up going with FI and never got back to the nitrous....maybe in the future though.
captchaos
Mar 15, 2016 12:18 PM
junito1
Sep 23, 2015 12:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
