Car is dead
Old Feb 9, 2003 | 03:56 PM
NmexMAX's Avatar
dot dot dot ...
Car is dead
Accessories sometimes work, but when turning the key to start, everything dies, and car does not start, battery is good, starter is also good, any suggestions? Fuses? I schecked all of the starter, acc. fuses and all of them are good. Maybe a bad ground connection?
Old Feb 9, 2003 | 04:46 PM
maxdis1's Avatar
Re: Car is dead
Uh, you might want to check the alternator, which you did not mention ?! Just my 0.2 cents.
Old Feb 9, 2003 | 04:56 PM
andreyyy's Avatar
does the engine crank ? if not i had a same problem a month ago
Old Feb 9, 2003 | 05:42 PM
tzmanles's Avatar
Re: Car is dead
when you say accessories sometimes work, do you mean everything starts working then slowly stops? Are your headlights dim? Does your windows go slllooowwwww down? If so, check your alternator. Thats the symptoms I had when Nissan had the alternator recall on my 97. I brought it in and they hooked me up with a new one.
Old Feb 10, 2003 | 06:16 AM
NmexMAX's Avatar
dot dot dot ...
Alt is good. I think it is a bad gnd connection b/c when just sitting there when I re-connect the gnd, the interior lights work and the clock works, but when I turn the key to acc. everything once again dies.
Old Feb 10, 2003 | 07:25 AM
fisher's Avatar
Are u sure battery is ok? I had a similar problem 2 weeks ago on our 99 maxima. Battery tested 12 volts under no load conditions. All accessories worked fine. Upon testing battery while cranking engine, battery showed 4 volts. (Way to weak) replaced battery all is fine now.
Old Feb 10, 2003 | 08:35 AM
NmexMAX's Avatar
dot dot dot ...
We boosted it and nothing, same thing, it died. So we changed the battery to the other vehicle, and it started right up using my battery.
Old Feb 10, 2003 | 08:42 AM
97blackSE's Avatar
loose battery connection...thats what it sounds like to me
Old Feb 10, 2003 | 09:36 AM
95emeraldgxe's Avatar
sounds like an alternator problem to me.......are your brake and battery lights going off at the same time?
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Feb 1, 2016 12:45 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
