Newbe question for 5-speed drivers
Old Feb 12, 2003 | 06:43 PM
Kolyan's Avatar
i am new to 5-speed and i was told that i MUST push the clutch all the way when shifting to avoid repairs. is this true?
Old Feb 12, 2003 | 06:50 PM
SonicDust187's Avatar
Re: Newbe question for 5-speed drivers
Yes.
Old Feb 12, 2003 | 06:51 PM
cantgofast's Avatar
Re: Re: Newbe question for 5-speed drivers
Originally posted by SonicDust187
Yes.
Old Feb 12, 2003 | 07:52 PM
sil SE's Avatar
lockdisbish
Old Feb 12, 2003 | 08:59 PM
Jason R's Avatar
aka UNCDooD
yea...
Originally posted by sil SE
lockdisbish
Old Feb 12, 2003 | 09:04 PM
95CustomMaxima's Avatar
lockdisbish
Old Feb 12, 2003 | 10:37 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
ahhhh... yes you should.
Old Feb 12, 2003 | 10:40 PM
thurmer85's Avatar
i would unless you like the smell of a burning clutch i dont like it that much so i push the clutch in all the way not to mention the money to replace it
Old Feb 12, 2003 | 10:46 PM
meccanoble's Avatar
Sports Button FTW
Old Feb 13, 2003 | 09:13 AM
Stephen Max's Avatar
You only need to push the clutch pedal in until the clutch disengages from the flywheel. Depending on how your pedal is adjusted, that could be all the way to the floor or only half-way. If it completely disengages at the half-way to the floor point, there is nothing more to be gained by pushing the pedal the rest of the way to the floor. The transmission doesn't care if there is one inch of separation between the clutch and the flywheel or only .1".
Old Feb 13, 2003 | 11:46 AM
96SE5Spd's Avatar
To an extent but as long as the clutch is disengaging then it doesn't matter. If it is not disengaged and you shift the shifter will kind of pop out of gear and may or may not go into the gear you are trying to put it in. Either way you'll know it if the clutch is engaged at all.
Old Feb 13, 2003 | 04:02 PM
Kolyan's Avatar
ok.....here is another thing though.....when i shift to 1-ST gear i sometimes hear the sound that is not supposed to be there, other shifting is fine. it's not me doing something wrong, it's defenatly something else. any ideas on this would help, thanks. oh and the car feels kinda weak in 1-ST.
Old Feb 13, 2003 | 05:35 PM
cantgofast's Avatar
Do you mean downshifting into 1st while still rollong? if so thats a
Old Feb 13, 2003 | 06:36 PM
dashingMax's Avatar
This article might help you
Link...
How to drive a car with a manual transmission
Cheers!
Old Feb 13, 2003 | 06:38 PM
kratz74's Avatar
If your in another gear and want to shift to first you really should stop first or slow to a crawl. If you are stopped and still have an issue. Put the car in a another gear like 3rd and then back into first, it may help. Of course the clutch should be pressed when changing your gears
As for your first question. Since you are new at the 5 speed, you should depress the clutch all the way to the floor until your get better acqainted with the car. Then you can cheat a little bit depending on your cars clutch (every car is a little different).
Old Feb 13, 2003 | 08:30 PM
Kolyan's Avatar
i am not down-shifting, i am shifting from neutral to 1 and sometimes it makes this noise which i can only hear if the radio is off. i am not a bad 5-speed driver, and i don't stall, i can drive 5-speed, it's just my first manual car. oh and i can avoid the noise by pressing the cluch in a different way but the way i am doing it the car still should't make that noise.
Old Feb 13, 2003 | 09:13 PM
BOZOnPJs's Avatar
i've half clutched on my past 2 cars to upshift, and i've gotten over 120,000 miles on each original clutch.... go figure.
boomerbrian
Oct 31, 2018 10:25 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
