Wiper Fluid Motor or gunked up lines?
Old Feb 16, 2003 | 02:14 PM
T Mac's Avatar
My wife pointed out to me that her washer fluid doesn't come out any more. I went out and looked it over. There's plenty of fluid in the tank, the wipers work like a champ. Should I be able to hear the motor hum when I turn the wiper fluid on? I don't.
So what I'm wondering is whether I have some blocked up lines or a bad wiper fluid motor. Any thoughts or suggestions anyone??
Thanks!
Old Feb 16, 2003 | 04:56 PM
nadir_s's Avatar
vicodin ... gift of life
Re: Wiper Fluid Motor or gunked up lines?
Thanks!
if you don't hear that "whirring" sound (motor) when you try to use the washer fluid, then it means the motor is gone.
Old Feb 16, 2003 | 06:39 PM
Indecisive311's Avatar
Your lines will never gunk up if you use windshield washer fluid because of the chemicals in it. The tip where it comes out can get clogged though. It deffinetly sounds like the motor. I don't know where the fuse is for it but check that first.
Peace - Chad
Old Feb 16, 2003 | 07:12 PM
Maxima95Tuner
When I bought my car used, the motor for the fluid was shot. Also, when my mom bought her maxima used a few years back, the same thing happened to hers about a year after. We never bothered to replace anything in it. It's most likely your motor though. Common problem on maximas.
Old Feb 16, 2003 | 08:20 PM
Mishmosh's Avatar
Yeah... it seemingly is pretty common. Just get an OEM replacement because it accepts the stock harness... or Autozone will have an aftermarket unit for a few bucks cheaper if you don't mind rigging up the wiring. I think the OEM is about $20 and aftermarket, maybe $12. The motor is attached to the windshield washer reservoir in case you are wondering. You just peel back the fender well lining in front and there it is...
captchaos
Mar 15, 2016 12:18 PM
Johnny9595
Sep 16, 2015 07:20 PM
Maxxx10
Sep 13, 2015 03:16 PM
