Brake fluid is black, how do i replace???
Old Feb 16, 2003 | 03:49 PM
MaxEffect414's Avatar
My brake fluid is like black and i want to flush it out and put new, anyway know the procedure???
Thanks, Trance
Old Feb 16, 2003 | 04:57 PM
sleeper's Avatar
brake fluid
take it to the shop. they will need to get all the dirty fluid out, using air pressure. then add fresh fluid and bleed master cylinder and brake lines.
Old Feb 16, 2003 | 05:01 PM
What's the aprox cost on that???
Old Feb 16, 2003 | 06:44 PM
rcy's Avatar
rcy
Re: brake fluid
Couldn't he just bleed his brake lines - keep adding fresh fluid to the reservoir till fresh fluid comes out at each wheel?
Old Feb 16, 2003 | 06:57 PM
D-sta's Avatar
Re: Re: brake fluid
yes he can
Old Feb 16, 2003 | 06:58 PM
maxspeed96's Avatar
thats what the shop would probably do and charge $50/hr. you can do it for just the cost of the fluid. do it yourself and save some money.
Old Feb 16, 2003 | 10:00 PM
I was thinking about that but wouldn't i have to bleed each wheel because it looks to me like from the reservoir there are 4 individual lines going to each wheel...
Trance
Old Feb 17, 2003 | 06:19 AM
iwannabmw's Avatar
Trance
Yes, you will have to bleed each wheel to do this. You should do this anyway though. All that old nasty fluid is in those lines, and the calipers as well, and really should be flushed out too.
Old Feb 17, 2003 | 01:32 PM
sleeper's Avatar
at $65.00 per hr., it would probably take at least 1-2 hr., you should use brake fluid that can handle high temp., i use valvoline synthetic brake fluid. dirty brake fluid is a bad sign. i would thoroughly clean(flush out) the entire system. the negative about bleeding yourself is that you might break off a bleeder valve, and then that would delay your process, then you would have to
Old Feb 17, 2003 | 01:37 PM
Stephen Max's Avatar
Re: Brake fluid is black, how do i replace???
Thanks, Trance
Get some Speedbleeders and it's very easy.
speedbleeder
Old Feb 17, 2003 | 05:31 PM
Thanks guy's and the spped bleeder looks cool i'm gonna check it out...
Trance
homeyclaus
Sep 3, 2015 06:15 PM
homewrecker
Aug 24, 2015 08:56 PM
Mrbizness1
Aug 18, 2015 08:43 PM
egali045
Aug 16, 2015 01:19 PM
