info about red/clears...
Old Feb 20, 2003 | 02:21 PM
MIDNightMAX84's Avatar
just got my 99 max SE Limited 5sp. I want to get the red/clears and heard about inserts u can buy for about 20 dollars...do these look as good as the ones from custommaxima.com, which are around 200 dollars?
Old Feb 20, 2003 | 02:50 PM
SpeedFrk38's Avatar
what u could do is start up a group deal with custommaxima.
i got mine thru the GD and oh man ... they look NICE!
You can do the custom job but won't look as clean as custommaxima.
Old Feb 20, 2003 | 02:55 PM
97blackSE's Avatar
97metallicgxe makes inserts for 20 bucks...they look good...200 bucks is kind of a lotta money
Old Feb 20, 2003 | 05:32 PM
tzmanles's Avatar
be carefull if you decide to make your own with the inserts. I heard a lot of people cracked the lense by accident...there are a lot of threads on how to's by doin a search....good luck
Old Feb 20, 2003 | 08:30 PM
metallic97gxe's Avatar
Master Will
Originally posted by 97blackSE
metallic97gxe makes inserts for 20 bucks...they look good...200 bucks is kind of a lotta money
yes I can make you just the inserts...
thanks....
-Will
$20.00 shipped......
PS CustomMaxima uses an expensive machine to cut his I use my time,skill,and my dremel tool at home in my garage...
I try to do the best that I can...
Old Feb 20, 2003 | 08:34 PM
madmax97's Avatar
DIY
Just put them on a tray and pop in over at like 350 for 5-10 min keep checking. Get a butter knife or screw drive and pry but dont do it unless the glue in melted. I cracked mine trying to pry but u cat tell i just super glued the piece back on. Just make sure the glue is heated up enough and go round the whole casing and pry a little at a time. Get a peice of clear plastic from home depot, in the lighting section. It a square peice that you see in office bulding those thin sheets. And cut it out. Its simple. good luck
Old Feb 20, 2003 | 09:44 PM
Re: DIY
Thanks guys...i guess i will try the inserts that are only 20...
-brett
Apr 16, 2020 05:15 AM
bernyp
Oct 2, 2015 10:10 AM
fx4five
Oct 1, 2015 04:58 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
