auto transmission blues. why won't my car start??
Old Feb 22, 2003 | 08:54 PM
silvermax2k2's Avatar
i should have never taken apart my max! i installed a new radio in my car, and ever since then it has been doing something really odd. IT WON'T START! i turn the key to go start it, but i just hear "click" and my clock, my radio, and dash lights turn off, and then when i let go of the key (like when we let go of the key once the car is started) everything comes back on. so i got mad and just for the hell of it i moved my drive selector into reverse, and then back into park again, and turned the key and my engine started!
now my car does this 75% of the time i get into it, and it is really annoying. does anyone know what this is, and how to fix it? thanks.
chris
Old Feb 22, 2003 | 11:34 PM
96_vqmax's Avatar
Re: auto transmission blues. why won't my car start??
chris
I think you should remove the panel surround the shifter to check and see if there was anything jamming your shifter.If not then your shifter prolly need to be adjust.Hope this will help.
Old Feb 23, 2003 | 12:39 AM
erty67's Avatar
Decal Specialist
Chris, I agree with 96_vqmax. It sounds like there may be something blocking you from getting the shift all the way into park. I would take that panel off and check. I see your luck continues
Old Feb 23, 2003 | 03:50 AM
superblack96's Avatar
Not sure if the Max has one, but my wifes 92 SL2 had a park-neutral switch that wen bad. Had to do the same thing to get it to start- Move the gear selector back and fro - I replaced it and it never did again - Just a thought- Like I said don't know if the Max has one, but maybe a place to start - Tucker
Old Feb 23, 2003 | 03:52 AM
Oh yeah, the park-net switch is a relay like device that tells the car when it is in park and net. It won't let the car start in any other gear. If it goes bad, the car thinks it's in gear all the time and won't start - tucker
Old Feb 23, 2003 | 08:40 AM
Lime's Avatar
it's called the neutral safety switch.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Stagnet04
Aug 16, 2015 11:15 PM
Trin1j23
Aug 12, 2015 08:31 PM
mrgooch
Aug 9, 2015 11:00 AM
