What is MEVI ?? (merged threads)
Old Feb 23, 2003 | 11:16 AM
maxspeed96CT's Avatar
The original VQ...
What is MEVI ??
What id the MEVi mod , alot of people talk about it but icant figure waht it is, some please tell me.
Old Feb 23, 2003 | 11:19 AM
Confused's Avatar
Permanent Maxima.org Resident
Re: What is MEVI ??
Page two of the FAQ listed on top of the forum.
http://forums.maxima.org/showthread.php?threadid=72447
Old Feb 23, 2003 | 11:40 AM
Sprint's Avatar
Medium Errogenous Vaginal Infection
Old Feb 23, 2003 | 12:00 PM
iregula's Avatar
yeh we all have it. dont u?
Old Feb 23, 2003 | 12:27 PM
The original VQ...
haha, if this is a mod than i can be without
Old Feb 23, 2003 | 12:40 PM
arlan's Avatar
Re: Re: What is MEVI ??
thanks a lot, i had the same question.
Old Feb 23, 2003 | 01:30 PM
Maxima95Tuner
HAHAHAHAHA
Old Feb 23, 2003 | 04:16 PM
brizsblackmax's Avatar
omg lol wtf is it does nebody know???
Old Feb 23, 2003 | 04:27 PM
The original VQ...
I dont know but i cant find it , i serched those pages like 3 times
Old Feb 23, 2003 | 05:06 PM
dwapenyi's Avatar
You know what? It's not on page 2. Little typo needs to be corrected.
Anyhow, to find the info, pull up the link below, at the top of the thread, on the right hand side, click "show Printable version." Once your browser has finished downloading the entire 40 pages into one long thread, use Edit->Find(On this page) and find for MEVI. The info will pop up. Do a find again and even more info shows up.
DW
Old Feb 23, 2003 | 05:10 PM
Maxima95Tuner
I think it means Middle Eastern Variable Intake. What it does, is at lower RPM, your intake will function with less airflow, and at higher RPM, it will open up a little door letting more air flow into the manifold. Correct me if Im wrong, but I think that's how it works.
Old Feb 23, 2003 | 05:18 PM
BBaker025's Avatar
If you people could search around for 5 seconds or read all the FAQS it would be much easier then waisting bandwith with usless threads.
What is the MEVI ?
The MEVI, Middle East Variable Intake (Don't know the official name) is a 4th Gen thing...
The Infiniti I30 is sold in the Middle East (Bahrian, Saudi etc) under the name Maxima, and it has a specially-designed intake.
It's not a true Dual-Plane intake (like the Taurus SHO, or the 3.8 SPI from the later model Windstar/Mustang) which has two distinct air paths from the air filter to each cylinder (one long, for low revs - one short for high revs). Instead, it's a Dual-Plenum design that has a second plenum directly above the lower intake, providing a shorter path for the Dynamic Supercharging effect (described below). The second plenum is 'activated' by opening a set of butterfly valves. These valves are opened by a vacuum actuator at the appropriate engine speed.
Dynamic Supercharging is the concept that when the intake valve closes it causes a pressure wave to travel from the outside of the intake valve back towards the air filter. When the pressure wave reaches the plenum (the common part of the intake track between the throttle body and the individual runners) it bounces back towards the intake valve. If the intake valve opens just as the pressure waves gets back, then more air is forced into the cylinders and it increases the volumetric efficiency. There is a specific engine speed at which this Dynamic Supercharging effect happens, and the length of the runners changes this engine speed, because of the time it takes the wave to travel.
Intake spacers change this effect to a lower engine speed (because the wave takes longer) giving the engine more bottom-end grunt (marginally, and at the cost of mid-range grunt)
The dual-plenum design gives the engine TWO speeds at which dynamic supercharging happens - at high speed the upper plenum valves open and the shorter path to the upper plenum gives the dynamic superchargin effect at higher engine speeds, increasing breathing and prolonging the powerband.
That's it, in a nutshell.
Credit: Scruit
Old Feb 23, 2003 | 05:30 PM
The original VQ...
ahhhhh... THANKYOU
Old Feb 24, 2003 | 02:29 AM
Triocet's Avatar
Mevi!!
ok, i've been searching for a while and nothing, so i'll be blunt
where can i get a MEVI for 95 maxima and how much will it cost??
Old Feb 24, 2003 | 02:54 AM
superblack96's Avatar
Look here man- This is the current GD for MEVI's- Prie is on the last few pages, he's got a install kit now too! -
http://forums.maxima.org/showthread....hreadid=151928
- Tucker
-PS- No flaming guys, it is hard to search and find where to buy it!
Old Feb 24, 2003 | 04:26 AM
BBaker025's Avatar
Read the last page of the 4th gen FAQS.
Old Feb 24, 2003 | 05:16 AM
Sprint's Avatar
how do newbies know that the MEVI exists if they didn't read about it some where?
Old Feb 24, 2003 | 05:22 AM
Triocet's Avatar
it's not about knowing wether it exists or not, its about finding out where to get one, there were a lot of posts that explained what it was but none of them said anything about where to find one.
thanks superblack for the link..
Old Feb 24, 2003 | 05:28 AM
Sprint's Avatar
maybe not yours.. but definately this one.. http://forums.maxima.org/showthread.php?threadid=191649
Old Feb 24, 2003 | 06:42 AM
clee130's Avatar
Re: Re: Re: What is MEVI ??
DW
Sure it's on page 2.
If you have your settings to 40 posts a page, it's on page 2 in a 3 page thread.
Old Feb 24, 2003 | 07:05 AM
Sprint's Avatar
Re: Re: Re: Re: What is MEVI ??
40 page view ownz
i have to gtr_rider anytime he sends me a link with like page 5 on it.. i click it.. and its blank..
come on people.. you don't have to read 14 page threads when they can be 5 with 40 page view
Old Feb 24, 2003 | 07:07 AM
clee130's Avatar
Re: Re: Re: Re: Re: What is MEVI ??
40 page view ownz
Exactly, I understand before when there were sigs in every post and loading times would be slow with all the images, but now, one sig per person on a page + no pics in sigs means all text which means fast-loading pages.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
