Cylinder Misfire?
Old Feb 24, 2003 | 07:42 PM
owen24's Avatar
Cylinder Misfire?
Hi all!
I checked my "service engine soon" light and the codes were 0607 (Cylinder no. 2 misfire detected) and 0201 (Ignition signal primary circuit fault)
Do I have to my '99 max to a dealership to have it serviced or are these things that others have seen and can be fixed? Thanks in advance for any help or insight provided!
Owen
Old Feb 25, 2003 | 11:15 AM
Romeo's Avatar
try this:
swap plugs from #2 to #4 and swap the coil from #2 to #6. reset your ecu. if you have a cylinder misfire in #4, you have a bad spark plug, if you have a cylinder misfire in #6, you have a bad coil.
Old Feb 25, 2003 | 12:58 PM
owen24's Avatar
Thanks! I'm gonna try this tonight and hopefully can avoid having to take it into the shop.
With that being said...if I drive like this for a while do I run the risk of causing more damage? I figure it's ok...I have not heard or felt any rough idleing or anything to raise a red flag.
Thanks!!!
Owen
Old Feb 25, 2003 | 01:46 PM
Romeo's Avatar
you should be ok. i drove my old maxima a few hundred miles with only 5 cylinders. also be aware that it could be countless other things that would trigger a code like that.
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
