Cut-a-Coil questions
Old Mar 10, 2003 | 02:09 PM
Bad97MaxSE's Avatar
Down falls ?
Thoughts ?
I understand many have done this. Search function is down right know.
Old Mar 10, 2003 | 02:25 PM
BRIGBOY's Avatar
The main draw back is if you make a slight error on the even cut on both springs, the car will not sit level.
Its a good inexpensive way to get the drop your after.
In no way shape or form would I (or almost any other member) suggest cutting stock coils to get a drop, they are way to soft.
Old Mar 10, 2003 | 02:48 PM
matty's Avatar
Yes
To cut a dead coil off a spring to get an even drop is ok, but to cut stock coil springs to get a drop is a big NO NO...your just asking for trouble
-matt
Old Mar 10, 2003 | 03:07 PM
Vyrus's Avatar
That's exactly right. If you want a little lower, go with lower springs or coilovers. I have the lowest springs and I don't want the hassle of coilovers so I cut a coil. As matty said, it is 100% fine as long as you are cutting a dead coil, but NEVER cut an active coil. And make sure you cut them even too like Brigboy said, or might have some problems.
-Cyrus
Old Mar 10, 2003 | 03:18 PM
danimsta's Avatar
sorry, but can u tell me what a "dead coil" is?
Old Mar 10, 2003 | 05:49 PM
Bad97MaxSE's Avatar
Originally posted by matty
Yes
-matt
i have the Dropzones. Whats a dead coil ? can you cut a half ?? lol
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
