Turn Signal Help!
Turn Signal Help!
Today i attempted to do the "alternating turn signal mod" for the bumper lights. I tried out one side, following instructions according to maximadriver.com and when i tested it out, nothing happens! When I try to turn on the turn signal for both directions, as well as turn on the hazards, nothing happens. Theres no "click-click" noise anymore or no green arrow on the dash board. Im hoping that maybe i just blew the fuse and nothing more. Anyways, where is the fuse for the turn signals located??
look in the fuse box under the steering wheel, it should be in there. did u cut the wires like it says? and did u cut the right ones? i did the mod to mine before and never had a prob, unless ur wires touched weird or somethin
Which fuse is it called?? The one called "turn"? Well I swapped the same amp fuse with another one to test and it still didnt work!...Startin to worry now..
And yea I cut the Ground (black) wire from the side marker and spliced it to the Positive (red) wire from the turn signal.
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
Stupid me, yea i changed the fuse, but i forgot that i needed the key on ACC for the turn signals to work.
