Stillen Intake (95 maxima)
Old Mar 11, 2003 | 07:22 PM
Stick Max's Avatar
I just recently installed a stillen intake, into my maxima. Theres two sensors for a 95 maxima. an airflow sensor and from what I heard a temperature sensor that goes directly into the filter itself. The one that is the airflow sensor plugs back in, but the temp sensor is in the form of an ellipse and theres only enough space for a circle shaped form in the intake. My mechanic said that the sensor needs to be in and he doesnt recommend, leaving the stillen intake in. He says that theres no spherical sensor that fits in that intake. anyone know of one? what do you reccomend
Old Mar 11, 2003 | 07:32 PM
Toolrocks's Avatar
The stillen intake has a hole at the end where the stillen logo appears. There should also be two screw holes there as well. Remove the air temp sensor from your factory intake box, it is secured w/ two screws. Once you remove the sensor you'll see that it is round and has an elliptical base - it will fit. Install the removed sensor into the Stillen intake and plug the harness back in. Hope that's clear.
Old Mar 11, 2003 | 08:21 PM
Stick Max's Avatar
IM not sure
the description is quite clear aside from 2 problems, 1 I dont think the stillen intake has two holes, 2 I really dont think that the sensor is in the shape of a circle.... i will take pictures tommorow and post maybe you can help me then.
Old Mar 11, 2003 | 08:53 PM
stephenlc's Avatar
You probally got one for the 97-99 becuase their Intake temp. sensor is different than the 95-96. just my 2 cents.
Old Mar 11, 2003 | 09:29 PM
SoLid97SE's Avatar
wait...i have a 97 and my friend is selling me his stillen intake from his 95. is there going to be a prob? hopefully not..
Old Mar 11, 2003 | 09:35 PM
96_vqmax's Avatar
Yep,the 95-96 has three holes on the filter.You prolly got the 97-99 one that doesn't have any hole on it.But you can drill 3 holes on the Stillen K/N filter to put it on there.Hope this help.
Old Mar 11, 2003 | 09:46 PM
s600ergy's Avatar
yeap 95-96 amd 97-99 2 deferent ones
i have 96
http://maxima.cardomain.com/member_p...82_54_full.jpg
Old Mar 11, 2003 | 10:43 PM
96_vqmax's Avatar
Nope,all you need is find some washer and screw to plug the holes up.
Old Mar 12, 2003 | 08:37 AM
dmBK's Avatar
How 'bout them cliffs?
i installed a 97-99 stillen intake on my 96. i drilled 2 holes for the small screws, used a couple of washers, a sealer, and its all good.
Old Mar 12, 2003 | 11:46 AM
SoLid97SE's Avatar
so since i'm using an intake from a 95-96 then it should have holes when i don't need them right? so i don't need to drill...just plug up the holes?
Old Mar 12, 2003 | 12:03 PM
dmBK's Avatar
yup
Old Mar 12, 2003 | 12:23 PM
Stick Max's Avatar
So if I drill the holes is the sensor the same size?
if i drill the holes is the sensor from the 95 maxima the same size and will it fit? i dont wanna drill holes im not good at it ... whos got a maxima in philly
Old Mar 13, 2003 | 08:48 PM
96_vqmax's Avatar
Re: So if I drill the holes is the sensor the same size?
Well it's fairly ez to do it.All you got to do is remove the air temp sensor from your factory air box.There is a oval shape braket thing that hold your air temp sensor to the air box,use this oval thing and drill the holes same as the oval thing on to the filter.Hope this will help.
cheftoo
Aug 20, 2015 05:17 AM
Dman1989
19
Aug 17, 2015 03:44 AM
wyobbagy
Aug 15, 2015 02:28 PM
Team STILLEN
Aug 10, 2015 04:29 PM
