maxima studderz
Old Mar 12, 2003 | 12:20 AM
mr. bunna's Avatar
maxima studderz
ok check this out. my girl's maxima studder's when tha brake is applied at a full stop while the car is in gear. when it's in park or neutral it's fine. it sound's like the engine knock's like it's about to die. knock's then ok then knocks then ok. n keep's going. now do you think this is spark plug,problems(i just recently changed them last week). or is it fuel pump, filter. anybody have any ideas?
Old Mar 12, 2003 | 12:28 AM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
Re: maxima studderz
What brand plugs did you change them to, and try cleaning your throttle body.
Old Mar 12, 2003 | 01:00 AM
Nismo's Avatar
at worst it may be a dying MAF sensor.
Old Mar 12, 2003 | 01:09 AM
mr. bunna's Avatar
i used denso platinum plugs. and what's a MAF sensor. **** we just changed tha O2 sensors at tha dealership. and tha check engine light came back on again. anyways. im picking up my maxima. bought a 99 se-limited not stick tho. today so i should drop her's off n see what's wrong with it.
Old Mar 12, 2003 | 12:24 PM
The maf sensor is part of the stock intake. From the airbox, follow the intake up, and you'll see the MAF (Mass Air Flow) sensor. it's a tube with a rectangle on top with a plug plugged into it.
Ther thing is tho, i killed my MAF, and it wouldn't idle at all. You would have to start the car up and throw it in drive and stomp on the gas to keep it going.
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
