Car hesitates during acceleration
Old Mar 12, 2003 | 05:44 PM
max!mus's Avatar
All,
When I accelerate from a stop such as leaving an intersection, the car has a small hesitation. I even notice it when I'm in 4th or 5th gear giving it some gas to speed up. Its small but still noticeable.
I've had a tuneup and that did not fix it. What else could I look at?
It idles smoothe as silk. I get good gas mileage. Not sure what else to check.
Its a 98 SE with 82K on it.
thanks,
Stephen
Old Mar 12, 2003 | 06:59 PM
C3nthusiast's Avatar
Hesitation
Tighten your throttle cable..
Old Mar 12, 2003 | 07:48 PM
krbga's Avatar
You have a 98:
1. Spark Plugs -OEM Only (NGK PRF5G11)
2. Fuel Filter - 5minute mod
3. Throttle Body Cleaner - $3 can at Pep Boys
4. One of your Ignition Coils is bad. They range $98 to $108 each at the dealer. But you should have had a Check Engine Light go on.
Try 1,2 and 3 before you consider 4.
Old Mar 12, 2003 | 08:22 PM
Re: Hesitation
Originally posted by C3nthusiast
Tighten your throttle cable.. Every ORG members car that I have put an alarm in has suffered from a loose throttle cable.
Old Mar 12, 2003 | 08:30 PM
billy_corgan's Avatar
Re: Car hesitates during acceleration
Originally posted by max!mus
All,
thanks,
Stephen
the same thing happenened to me and mine was a knock sensor. pull some codes from your ECU. see if you get 0304. remember the knock sensor itself cant trip the CEL. I am almost positive it is the knock sensor!
Old Mar 13, 2003 | 12:26 PM
ChiTown Max's Avatar
Re: Re: Car hesitates during acceleration
Yep, same thing happened to me, and it was the knock sensor. Drove it around like that for a couple weeks before finally getting the CEL; O2 sensor went at the same time....
Old Mar 13, 2003 | 02:11 PM
djshawnee's Avatar
[/B]
5 minute mod! Its really hard to do..... especially if you have ABS like me. Also, how do you tighten the throttle cable?
Old Mar 13, 2003 | 02:22 PM
FLO_BOY's Avatar
Try this:
With the engine running, grab the main engine wire loom near the
firewall, beside the passengar side wheel well...Give the wire loom
a little bit of a shake, and see if your RPMs change.
On my car the engine wire loom, near the firewall, is wonky...there's
even a Technical Service Bulletin on this.
OR, TRY THIS:
There are two (maybe one) ground wires near the fuel rail, behind
the plastic "Nissan Maxima 3000" engine cover (not under it, behind it).
Let me know if you have questions...
take care!
FLO_BOY
Old Nov 26, 2011 | 04:21 PM
h0ldem_8o8's Avatar
It's probably a worn ignition coil
Old Nov 26, 2011 | 05:08 PM
comingup's Avatar
I have ABS, 5 minute mod bro
Old Nov 26, 2011 | 05:46 PM
T_Behr904's Avatar
Why are noobs all of a sudden bumping ancient threads? And bumping a thread that's almost 9 years old?
Old Nov 27, 2011 | 01:10 AM
Nissanserguy's Avatar
LOL to get his thread count...
Old Dec 13, 2011 | 10:54 PM
h0ldem_8o8's Avatar
I fixed my hesitation while acceleration, rough idle, and engine stalling problems. I changed the MAF, and it fixed all my problems. At first i tested the MAF with a multimeter, and it proved ok, but thats because the MAF wasn't acting up at the time. So i just drove around with the multimeter in my car, and when the idle was getting rough, and i knew it was acting up, I quickly pulled over to the side of the road, and tested it. Volla!! it didn't pass the test, it was actually faulty. So when testing a MAF, you must test it when it's acting up!! I also changed my idle air control valve prior to changing my MAF, and it fixed the problem for a day or two, then it went back to bad.
Old Dec 14, 2011 | 12:01 AM
ShocknAwe's Avatar
sometimes....late at night....I find the oldest thread I can....write a post to the effect of I second that or maybe even a simple "cool"....then wait for batman to appear....
Old Jun 4, 2012 | 03:06 PM
808HIMAX's Avatar
2002 maxima hesitation after stop
i got a similar stiuation here....96K mile on car, AUTO.
when cold or after a 10 min. ride, car will hesitate out of a stop.No codes pulled up on CEL. I changed the all spark plugs and coil packs, MAF is new, fuel pump new.Leaning toward a faulty Crank sensor...But dealer said it will pull a code.
the Car is at the nissan dealer Professional's now...they can't see any problems. TB bulliten was updated and they relearn all throttle postions.No codes pull up on there system(car seems fine they say).only thing was the A-apha was runing rich in the air to fule mixture %,with the K&N air filter cold intake.but this should not matter.the air filter was install @ 20,000. miles.Dealer is test driveing it with code capture device.But the hesitation is not happening now.Like always...when You bring it to the Doctors.the car acts fine....
Keep You posted on the results.
Old Jun 5, 2012 | 06:23 PM
jayeyeMax's Avatar
i dont see whats the big deal about bumping on a old thread? does it really bother people that much. alot of these "old threads" answer questions.
Old Jun 6, 2012 | 02:36 AM
808HIMAX's Avatar
Verdict.....1 Coil pack on spark plug was bad(intermittant)...misfire, causing hesitation while accelertion out of stop.rich fuel air-fuel ratio at O2 sensors.
this is the answer to the problems..
Lakersallday24
Jun 16, 2019 01:35 AM
scarletsosa
Aug 17, 2015 09:09 PM
Stagnet04
Aug 16, 2015 11:15 PM
Bruceharrison
Aug 9, 2015 07:56 AM
acw
Aug 7, 2015 04:20 PM
