Help with IAC valve OHM measure results.........
Ok I got the check engine light for the IAC valve, (AKA sensor 0205).
I have the Haynes manual and they said i could check the resistor on it the IAC valve, and i did. this is the results i got.
Terminal 1,2=38.3
Terminal 2,3=38.3
Terminal 3,4=34.2
Terminal 4,5=34.2
Haynes manual mentions they should be around 30 ohms but they are higher so i want to be sure if that IAC valve is bad.
I really need someone to check there IAC valve terminal and tell me what reading they get. please if you can I really appreciate it.
Terminal 1,2=38.3
Terminal 2,3=38.3
Terminal 3,4=34.2
Terminal 4,5=34.2
Re: IAC valve OHM measure results.........
Terminal 1,2=38.3
Terminal 2,3=38.3
Terminal 3,4=34.2
Terminal 4,5=34.2
Terminal 1,2=38.3
Terminal 2,3=38.3
Terminal 3,4=34.2
Terminal 4,5=34.2
PM or email me if you need further info from a FSM.
Hope this helps.
Dave
Re: Re: IAC valve OHM measure results.........
Originally posted by Dave Holmes
FSM ('97) says to check resistance between terminal 2 and terminals 1,3 then terminal 5 and terminals 4,6. Resistance should be approx 30 ohms at 20 degrees C (or 68 degrees F). Looks like you checked between 3 and 4 which isn't needed/correct, and you left out between 5 and 6. Your values look good, though, because it varies with temp, and 30 ohms is an approximate. If that part was bad, I'd think you'd get an infinite reading or something drastically higher. You can also check the mechanical operation of it by: 1) Remove idle air adjusting assembly (IACV-AAC valve is built in). 2) leave the electrical connector plugged in. 3) turn ignition switch "on" and "off" making sure the IACV-AAC valve shaft moves freely back and forth according to ignition switch position. If negative, replace valve.
Hope this helps.
Dave
Hope this helps.
Dave
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Nov 15, 2020 11:52 AM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
