Do You Want To Dimmer Your Indigo With Stock Dimmer?
Old Mar 14, 2003 | 05:57 PM
maximabest's Avatar
Man i just installed my superwhite gauges form procarparts.com I was with me electronic friend....to see what i was doing...and he said, Bro...dont attach the power supply with the stock cables, just do this............Man its very easy. Well you have two harness right? one red and one black(with your superwhite gauges transf), that you suppose to attach to the stock power supply harnnes....well....the only thing you should do is...take out one of the light bulbs of the needles, miles etc...choose one..and you will see a little part of metal that is the part which the bulbs takes the electricity...so!!!! you just put both(black and red) with contact to the metal. After that(you should put the bulb again and the bulb)....is the same process(reinstall the gauge, etc etc etc...) and you will not need to cut some stock harness again. You superwhite gauges will work with your stock dimmer.(cause the metal that has the contact with the needle bulb or whatever...will get more or less power when you control the dimmer...so you superwhite will work the same way)bla bla bla...
jejeje sorry for my bad thread...as i used to, its friday!!! yohooo a couple of beers!!!
aw11power
Oct 10, 2021 04:57 AM
gavin68
Sep 18, 2021 12:36 PM
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
