car hesitating / missing at about 3500 rpm
My 99 nissan maxima started missing / hesitating at about 3500 RPM this morning. After 3500 it continues to feel like it is hesitating. I just had a 60K tuneup but was wondering if anyone has any suggestions.
Also, the reason I really realized it was I put an intake on today and it would pop almost like the intake was back firing at 3500. I put the stock box back on and it still does it.
Should I get some fuel injector cleaner?
Slop
Slop
Originally posted by dwapenyi
Maybe one of your spark plug coils was not plugged in properly. Check those.
DW
DW
Would this cause my car to miss after 3500 RPM at WOT?
I don't know hopefully that is all that is wrong.
Slop
Chances are, that's it. The worng plug gap will make the engine act real funny.
DW
DW
Any ideas?
Slop
Since you've cleaned up the plugs, the only other area to look is at the newly installed intake. An air leak somewhere around the intake could be the culprit. Leave your engine running and rev the motor at the throttle body cable in the engine bay. Listen for any rushing air where it's not supposed to be.
DW
DW
Originally posted by slop00
Changed the plugs still happens. I find this interesting though, if I accelerate normally after 3500 it is fine. It only happens at WOT after 3500.
Any ideas?
Slop
Any ideas?
Slop
Re: AHHHHHHHHHH
Originally posted by T2CTeamShift
Man the same is happening to me right now, ITS SO loud and it happend like a Machine Gun, it got worse when I put my intake on.
This loud popping only occurs sometimes and from 3500 to 5000 it does it then it stops. Like last night I drove 20 miles and it did it after a little bit. It went away then. It seems like it does it when it feels like it.
Anyone know what this might be.
Re: Re: AHHHHHHHHHH
yeah he did.. he posted in general that it was his coil packs..
Did you find out what the problem was because I still haven't figured out what is wrong. I have tried new plugs, check connections, listen for air leaks, and still can't figure it out.
AHHHHHHHHH
Im back, Just stop flooring your car for a while, it should go away, but you still need to replace the sparks, Im gonna go get mines from a performance tuning store for cheap! Im getting the NGK Platinum 4 headed sparks, theyre like 14 a pop but the guy is hooking me up so it gonna be a lot less, I got some power back yesterday and I was flying, It wasnt Misfiring at all, I got to 70 b4 the end of a block, with a Heavy A$$ driver(Me) and someone thats chubby next to me. YAY
Re: AHHHHHHHHH
slop
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
