Noises from engine wheel area please take a look.
Old Mar 16, 2003 | 10:33 PM
madmax97's Avatar
There is a knocking sorta sound from front of car more towards the wheels i think. The noise seems to come when im turning the wheel, and sometimes over bumps. Also today when i parked my car i got out in it made this sqeek noise, my wheel was turned to the left. Soi turned it straight and nothing. I hate freaking noises, i have sprints and kybs if that helps. CAn being low hurt oem parts that arnt made for the car to be droped, like is an axel gonna break or something weird. Any thing you guys got will help thanks.
Old Mar 16, 2003 | 10:57 PM
k-man's Avatar
cv joint?
Old Mar 17, 2003 | 02:28 AM
Nismo's Avatar
try torquing the center strut nut 50 ft lbs ans see what happends.
Old Mar 17, 2003 | 05:10 AM
superblack96's Avatar
Wheel bearings?
This sounds alot like my old problem. My wheel bearings(both sides) went bad and started with a little noise and grad turned into a loud grinding noise. I believe if you jack up your car, you can check your bearings by trying to shake the wheel itself. Not rotate it, but shake it. Not sure exactly, maybe someone else has the exacts - Hope this helps -
-Tucker
Old Mar 17, 2003 | 05:55 AM
MyGray96SE's Avatar
Did you replace your front strut bearings when you put on your new springs?
Matt93SE
May 24, 2019 02:58 PM
maxinout93
Oct 27, 2015 01:29 PM
Starrider
Sep 17, 2015 07:26 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
