Front right heated O2 sensor
Old Mar 17, 2003 | 03:25 PM
Odie96's Avatar
My engine light just came on and it's telling me I need a front right heated O2 sensor...What could go wrong if I don't change it ASAP? Is it major in any way?
Old Mar 17, 2003 | 04:40 PM
StygianMax's Avatar
Re: Front right heated O2 sensor
My car just threw up an 0707 rear heated 02 sensor. I just we both need some answers. Have you reset your CEL?
Old Mar 17, 2003 | 04:43 PM
Odie96's Avatar
Yeah, I reset it right after I got home and checked the code. I haven't driven it after though...I guess I'll see if it comes back on while I'm driving to work in the morning.
Old Mar 17, 2003 | 06:22 PM
Odie96's Avatar
no one knows anything about this?!?!?!?!
Old Apr 16, 2003 | 06:32 PM
cydrive's Avatar
hey bro..i have the same problem, only i got 2 sensors i need replaced..this might answer some of your questions...
http://www.buyoxygensensors.com/
scroll down, there's a Q & A thing. Hope that helps!
Old Apr 17, 2003 | 03:21 PM
MIXXMAX's Avatar
You can try cleaning it and see if the code comes back. I'm not sure what to use for cleaning, but my mechanic cleaned mine once, and the code never came back.
Old Apr 17, 2003 | 03:25 PM
95maxmadman's Avatar
Use brake cleaner.
Also, find where the harnesses are under the hood.
Use an Ohmeter, test the outer pins, they should be between
2.3-4.3ohms. If not, get a Bosch O2 sensor. They're cheapest.
Old Apr 17, 2003 | 07:55 PM
davey6693's Avatar
Definitely reset the ECU first. If it comes back then the worst you have to do is replace it. You should be more concerned about one of the two fronts going than the rear.
Old Apr 18, 2003 | 03:41 PM
redlantrn's Avatar
does anyone know if the front right 02 plugs into the harness thats at the front of the engine bank or towards the rear?
thanks
Old Apr 18, 2003 | 09:17 PM
(_8*(l)Homer's Avatar
thanks
I changed mine last week. The front right sensor plugs into the rear right engine. Rear left if you are looking under the hood standing in front of the car.
Just follow the wire up from the sensor. I could see my sensor through the engine.
(_8*(l)
Old Apr 19, 2003 | 06:23 AM
redlantrn's Avatar
[QUOTE]Originally posted by (_8*(l)Homer
[B]
thanks homer.
rbuswell
Nov 12, 2016 04:11 PM
homeyclaus
Sep 3, 2015 06:15 PM
Alberto10mg
Aug 25, 2015 12:54 PM
FlaMark
Aug 21, 2015 11:06 AM
