300 zx caliper question
Old Mar 20, 2003 | 11:27 AM
SmackDown85
Can someone please tell me what modifications have to be made to your rotors to make these calipers fit? The ones i am looking at are the 92-96 ALUMINUM front + rear set. I currently have Brembo xdrilled/slotted front and rear rotors and SS brake lines.
Please someone give me the rundown on these, i would really appreciate it!
also, do you have to get 300zx ss lines if you get the 300zx calipers? or can you use maxima ss lines and have it work properly? please guys let me know i really need help!!
dont make me end up like this guy --->
Old Mar 20, 2003 | 12:04 PM
Aaron's Avatar
Langley AFB Sux
Re: 300 zx caliper question
You need 300ZX rotors. You need 300ZX brake lines. Some have used the maxima ones but its not totally safe. ZX rotors are thicker 26 or 30 milimeters.....depending on which year calipers you get. The Maxima caliper has a banjo bolt fitting to attach the line. The 300ZX has a flared fitting. The banjo style fitting will not flow enough fluid to properly acctate the pistons, plus it wont fit anyway.
ZX rotors from Irotors.com are 140.....used ZX brake lines....10$ (got mine of ebay)
Other than shaving the A-arm area (it will rub the rotors since they are thicker) theres no other modifications needed other than wheels with enough clearance to fit the wider caliper.
Old Mar 20, 2003 | 01:11 PM
SmackDown85
so basically, if i wanted to do the 300zx caliper upgrade, i would have to trash my "maxima" brembo xdrilled/slotted rotors and get 300zx rotors right?
Old Mar 20, 2003 | 01:40 PM
psu max's Avatar
Re: Re: 300 zx caliper question
don't you also have to remove the dust shields or whatever they are called?
Old Mar 20, 2003 | 02:53 PM
Aaron's Avatar
Langley AFB Sux
Re: Re: Re: 300 zx caliper question
Yes, you do. Forgot about that.
Supposedly you can use maxima rotors......but I didnt bother to try since it seems unsafe to me.
Aaron
Old Mar 20, 2003 | 04:47 PM
redmaxpa007's Avatar
i SeE what you did therE
Re: Re: Re: Re: 300 zx caliper question
Aaron
what is the thickness of maxima rotors?
Old Mar 20, 2003 | 07:00 PM
GarthG's Avatar
Can you use Maxima mounting bolts to mount the calipers, or do you have to get the 300zx mounting bolts?
Old Mar 20, 2003 | 11:15 PM
Aaron's Avatar
Langley AFB Sux
Use the same mounting bolts. The ones that hold the torque brace on.
19mm I think
Old Mar 21, 2003 | 05:39 AM
Ramius83
Yeah, the 300ZX mounting bolts are a little too long. When installed, they will rub against the rotor/hub. So, I too used the Maxima bolts to hold them on.
Old Mar 21, 2003 | 06:00 AM
Re: Re: Re: Re: Re: 300 zx caliper question
imported_Nismo_max
Sep 21, 2015 07:24 PM
Mahmuth
Sep 17, 2015 11:45 AM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
sdotcarter
Sep 2, 2015 09:53 PM
