Question about ppl with underdrive pullies
Old Mar 21, 2003 | 06:19 PM
libo74's Avatar
Producto Colombiano
For those of you that have installed an underdrive pully, has the check engine light came on? Mine did, should I be worried?
thanks
Old Mar 21, 2003 | 06:21 PM
redmaxpa007's Avatar
i SeE what you did therE
Re: Question about ppl with underdrive pullies
thanks
check the code and see what it tells you..
i did not have a light come on...
Old Mar 21, 2003 | 07:24 PM
krismax's Avatar
Father of the 00 VI
My pulley has been on since late 99 ,no problems ever or CELS.
Old Mar 21, 2003 | 10:33 PM
95emeraldgxe's Avatar
thanks
which one do you have? RVM racing? i remember some people complaining about a CEL with that UDP
Old Mar 22, 2003 | 04:05 AM
Shoooter_j's Avatar
Re: Re: Question about ppl with underdrive pullies
Really? what post was this comin up in?
Old Mar 22, 2003 | 09:41 AM
libo74's Avatar
Producto Colombiano
Re: Re: Re: Question about ppl with underdrive pullies
My situation has a couple different variables.
1) I had the RVM Pulley installed on thursday.
2) I picked up my car on Friday morning, and everything was fine. About an hour later I noticed that the CEL came on. So I immediatley assumed, that it had something to do with the pulley.
3) Later on that Friday I tried to start the car, but the car was having a hard time starting.
4) I had to physically bang the starter with a hammer to get the car to finally start. Which suggests that there might be a problem with the starter. Probably needs to be regreased?
anyways i'm going to check what codes the cel gives me, and then proceed from there. So at the moment it doesn't appear that the cel has anything to do with the pully.
P.S. does anyone have a link to the procedure on how to check for codes? I did it a long time ago, but i've forgotten. And how much do you have to donate to get the search function again?
thanks a lot for any help.
Libardo
Old Mar 22, 2003 | 12:45 PM
Lime's Avatar
http://forums.maxima.org/showthread.php?threadid=104931
has info on the codes
Are your belts hooked up correctly??
Old Mar 23, 2003 | 06:33 AM
libo74's Avatar
Producto Colombiano
Erica,
thank you so much for the link.
I checked the belts, and they seem to be alright, I'm in the process of cleaning out the starter gears, and re-greasing. Let's see if that works.
thanks again
Libardo
Old Mar 23, 2003 | 08:45 AM
Anachronism's Avatar
Does the pully have a timing ring on the back? Its a flat piece of metal that has a couple of 'teeth' sticking out. The 2k2 does not need it but the 95-01 does, otherwise the 2k2 uses the same pully. Someone in the 5th gen forum spent a ton of money tring to figure out what was wrong with his car unil he relized his UDP did not have a timing ring. If the code is 'crankshaft position sensor' or something similer that could be the problem. I don't see how a UDP could affect your starter in any way though
No problems at all with mine.
Old Mar 23, 2003 | 11:54 AM
Shoooter_j's Avatar
Does it have exactly 4 teeth sticking out?
And is the timing ring's diameter the diameter of the pulley itself?
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
