View Poll Results: Whats the next Mod I Should Get ?
ACT Clutch
50.00%
Stillen Rear Sway Bar & Cattman Front Strut
31.25%
Unorthodox Racing Under Drive Pulley
18.75%
Voters: 16. You may not vote on this poll
Whats the next Mod I should Get ?
Old Mar 25, 2003 | 05:08 AM
Zeks 97SE's Avatar
Hey if your like me and you are busy trying to mod this and that on your max. How about helping me out a bit. Whats the next mode I should get ?
Old Mar 25, 2003 | 08:21 AM
TonyGotSkilz's Avatar
I'd Say the best mod is the lottery mod (you know the one where you win millions) if thats not possible i'm voting act clutch.
Old Mar 25, 2003 | 08:59 AM
luckee2bhere's Avatar
for the price of the clutch you could get UDP, ADDCO rsb, and a cheaper FSTB.
Old Mar 25, 2003 | 09:30 AM
TheMax95's Avatar
Is the udp really worth the money? What can it do for power?
I'd say go with the ACT clutch, if you still have the factory clutch on.
Old Mar 25, 2003 | 09:45 AM
.1 sec on the 1/4
Old Mar 25, 2003 | 10:41 AM
Zeks 97SE's Avatar
thanks for voting keep it up, and let me here some comments
thanks ...make sure you vote if you view the post
Old Mar 25, 2003 | 11:13 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i would agree. get a rvm pulley for 80, addco rsb for 120 or so and an ebay fstb normally around 40 or 50.
Old Mar 25, 2003 | 11:45 AM
vipervadim's Avatar
I like Maximas
i got a question about this RVM pulley -- i thought it was just in the works and was a stock lightweight pulley for the supercharger.. nothing like the smaller Under Drive Pulley from U/R. unless they make an Underdrive Pulley for $80!! i want to buy the UDP as well.
but in my opinion get the ACT!
-Vadim
Old Mar 25, 2003 | 12:13 PM
hacim105's Avatar
-Vadim
No the RVM is just as small as the U/R the only difference is that the RVM weighs .3lbs more the the U/R.
Old Mar 25, 2003 | 12:21 PM
redmaxpa007's Avatar
i SeE what you did therE
give each mod a number.. 1, 2, 3
then roll a 3 sided dice... beat 3 outa 5 wins!!
Old Mar 25, 2003 | 01:19 PM
maxspeed96CT's Avatar
The original VQ...
The act would help out all your other mods by planting the power beter.
Old Mar 26, 2003 | 05:18 AM
chris j vurnis's Avatar
It depends what you already have and how many miles you got.
If you are starting out bone stock, then I would suggest different things.
There isn't much point to make significant changes to the suspension without first improving the tires, because everything reacts through the tires.
Beyond that, everything then reacts through the frame. So a front strut tower is a good starting point.
Getting front camber and toe alignments dialed in does wonders for the steering response.
Old Mar 26, 2003 | 06:58 AM
G1Max's Avatar
I agree with the theory of adjusting the camber and toe, but the maxima has independent rear suspension and also the ride height is too high if you are going to drive aggressively. Put a set of springs on (I used Eibach) shocks and struts (KYB AGX), and a rear sway bar to connect the rear end. It is like driving a totally different car. The UDR pulley adds about 8-10 hp and is really easy to install if you want that little extra something
Old Mar 26, 2003 | 07:06 AM
id like to see a dyno with that
lrb6805
Sep 30, 2015 08:12 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
