I found a red button. / unknown items
Old Mar 25, 2003 | 12:39 PM
dpassino's Avatar
What the heck is this in my car. I am finding all sorts of things.... I just noticed it... anyone know?
1st i have an unknown Hitachi Boost Senser
2nd I have a red light that no one really knows that it is
3rd I have a red button that was hidden neer my hood release.. LOOK!
hitachi boost sensor
http://www.dpassino.com/car/DVC00503.JPG
http://www.dpassino.com/car/DVC00504.JPG
unknown red light next to dimmer
http://www.dpassino.com/car/DVC00507.JPG
unknown red button
http://www.dpassino.com/car/DVC00508.JPG
http://www.dpassino.com/car/DVC00509.JPG
sorry for the bad resolution, my cam sucks..
anyone got any ideas!! i dont want to touch it. I am not sure what it is. could be self destruct! lol
I bought it used.
1999 nissan max se
bought from dealership in october. used
any help would be GREATLY appreciated! lol
Dan
Old Mar 25, 2003 | 12:49 PM
Nick97SE's Avatar
The red light and red button look like they are part of an aftermarket alarm. Not sure about the boost sensor, but I think my car has one also.
-Nick
Old Mar 25, 2003 | 01:06 PM
dpassino's Avatar
-Nick
but why would the button be inside the car. if a theif breakes in, and they go under the steering wheel, look a red button, lets push it to turn off the alarm. how stupid is that!! arg!!!
edit: Oh also, if i had an aftermarket alarm, would I not see the brand name somewhere in my engine bay? if they removed it before they traded the car in or something, the red light would no longer work, and it does. ??
Old Mar 25, 2003 | 01:08 PM
Geophrum's Avatar
I have a button that looks exactly like that that is part of my DEI sidewinder 6500 car alarm... but the actual button is black... its so incase your alarm remote stops working you can press a code and it will disable the alarm.. the red light looks the same to... but i had mine on the other side of the steering wheel..
Old Mar 25, 2003 | 01:25 PM
dpassino's Avatar
Old Mar 25, 2003 | 01:27 PM
ZuMBLe's Avatar
The button is probably the valet button for your aftermarket alarm. Do you have a siren inside the hood? The stock alarm uses the horn so you won't see a siren. Do yo use a nissan remote on the car? Boost sensor is normal. The red light next to dimmer is probably part of the alarm too.
Old Mar 25, 2003 | 01:28 PM
Geophrum's Avatar
the button is not as easy as just pressing it.. you hactually have a code that you need to press in order for it to disable
for example press it 3 times pause press 5 more times pause then 2 times and it will disable. (dont worry thats not my code hehehe)
as for not seeing anything.. does your car have an alarm at all.. meaning do you have a remot for your car.. and does the red light blink when the car is off or all the time?
reason i ask is there are silly people out there that install lights and buttons to make people thing ther eis an alarm on it...(I know.. but i had to ask!)
Old Mar 25, 2003 | 01:42 PM
dpassino's Avatar
I looked in my trunk to see if I had OEM keyless, and there is nothing in there. so i am confused. I read that you have to have something in there that shows you have it.
there is a siren thing on my firewall near the strut bolts. I am not sure if that is the horn or and alarm siren.. i am calling DEI to see if they can tell me how to determine if i have one of there alarms.
Old Mar 25, 2003 | 01:44 PM
Geophrum's Avatar
If there is an horn type device on your firewall on the passenger side...look ath the back of it it should say DEI or another name on the back of it... most likely that is the aftermarket alarm
ZuMBLe's Avatar
You have an aftermarket alarm. The horn doesn't look like the siren. You probably woul have no idea what the horn looks like. They are these disc like things. All that stuff is part of an aftermarket alarm. Do you use a remote to unlock the doors? Does your car make a sound when you arm the alarm?
Old Mar 25, 2003 | 01:46 PM
Juki5536's Avatar
Ya that button next to your steering wheel looks a lot like my Clifford light, just an indicator that your alarm is on (like the stock one on the opposite side)...At least, that's what I think it is, kinda hard to tell. Boost controller, maybe you're turbo'd and don't know it. Gotta go check my engine too, see if I'm boosted!!!
Old Mar 25, 2003 | 01:47 PM
ZuMBLe's Avatar
Everyone has a boost sensor. It's some type of vaccum sensor. No need to check your car. It's there. We all have it.
Old Mar 25, 2003 | 01:52 PM
dpassino's Avatar
here is my deal...
this guy from a security store said he would look to see if i have after market alarm, but I dont have the original Keyless entry remote or the thing in the trunk that I am suppose to have that allows me keyless etc although i do have the oem security light. ??
but i ordered a remote a while back from ebay, and tried to program it per intructions, and all the intructions i found say to do the same thing, get in car, manually lock doors, insert key 6-10 times within 10 second, hazards flash, hold down lock button, manually unlock door, get out, shut down, and push lock button. although my hazards dont flash.. lol so i dont even know if i have to OEM stuff.
I am going to try and see if i can tell what after market alarm i got. where do you think I could find the main peice of the alarm that would have the brand name or something on it?
Dan
Old Mar 25, 2003 | 01:55 PM
Geophrum's Avatar
here is my deal...
Dan
Just went and looked at mine the alarm thing that you said on the firewall should have some name on itthere is another box that is relays that i do not know were it was installed to that should also say
Old Mar 25, 2003 | 02:03 PM
dpassino's Avatar
alright, i got under there myself and looked behind the dash. i follow my button wire to is target and there is a little black box called "custom auto shield CAS971" I did a web search and NOTHING!
I at least want my OEM back so I can use remote. lol
Old Mar 25, 2003 | 03:08 PM
mzmtg's Avatar
Minister of Silly Walks
I don't have one
It functions as a MAP sensor. (Manifold Absolute Pressure)
Old Mar 25, 2003 | 03:49 PM
ZuMBLe's Avatar
How come you don't have one?
Originally posted by mzmtg
I don't have one
Old Mar 25, 2003 | 04:08 PM
mzmtg's Avatar
Because I have an early 95 that's not OBDII.
Check out this pic of my upper intake, notice anything else that I don't have compared to you?
Old Mar 26, 2003 | 05:09 AM
ZuMBLe's Avatar
I know exactly what you're missing. But my haynes manual uses an early 95 like your car and doesn't have it either. I don't know the name of it. It's that cone shaped thing with the hose at the end. That's the technical term for it, really. :P
Old Mar 26, 2003 | 07:35 AM
T2CTeamShift
Whao
My uncle has a Little Red Button next to his hood release, His car used to be a Police Interceptor, Try it out when your driving, HAHHAHA pull over some people, WTF i have one of those HITACHI craps too, WHAT IS IT, AHHHHHHHHH im scared holy crap
Old Mar 26, 2003 | 09:20 AM
Miasma's Avatar
yeah! lets hear it for early '95s!
Old Mar 26, 2003 | 11:03 AM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
so did you push it or what? Seriously, if i see a button, especially a red button, i have to push it. How can you resist? Just do it, and find out what happens.
Old Mar 26, 2003 | 11:10 AM
dpassino's Avatar
turns out to be a valet switch for some no name alarm brand. "custom autoshield, model CAS971" I cannot find it anywhere on hte internet.
Old Mar 26, 2003 | 12:08 PM
greenmax95se's Avatar
no name brand? try walmart maybe they'll have it seriously the past owner might have installed a cheap alarm in your max.
Old Mar 26, 2003 | 04:35 PM
Geophrum's Avatar
that could be the name of the relay that a spacific alarm used.
you found the nam only on that little black box. that is the alarm relay and it may just have the manufacture of that part.
even generic alarms are displayed someware on the net. i would keep researching... pull the peice off the firewall and look for a name on that and follow all the wires...
or do the next best thing... pull the whole thing out and put in a new one were you know were it came from hehehehe
Mar 12, 2020 12:06 AM
Stagnet04
Sep 14, 2015 11:28 PM
