Tire Size Recomendation
Old Jan 15, 2001 | 05:25 PM
black97max's Avatar
I am looking at getting new tires for the Maxima SE rims. I am thinking of getting the Dunlop 5000 Z rated all season performance tires. What tire size should I get?
Old Jan 15, 2001 | 05:26 PM
kutscher's Avatar
i put Kumho Ecsta tires on my 1998 se and they are great tires and expecially excellent for the price.
Old Jan 15, 2001 | 09:22 PM
dch95's Avatar
Size does/doesn,t matter
225/50/16!! If you can find them. That size runs a little more than 235/45/17.
Old Jan 15, 2001 | 09:55 PM
cliffp
225/50/16 kumho ecsta supra, excellent in handling and definitely great in price, try discounttires.com or tirerack.com
Old Jan 15, 2001 | 10:01 PM
AndyXXL's Avatar
hey black97max
I have Dunlop SP5000s all-season. My size is 225/55-16, very nice tires, get them.
Old Jan 15, 2001 | 10:08 PM
bigtexan7's Avatar
225-50-16 is the ticket. I'm running Dunlop sp8000. Z-rated, grip great! summer only tire.
Old Jan 15, 2001 | 10:09 PM
CFster's Avatar
SP5000
Just put on a set of SP5000s today. P225/55r16. I actually tried the 50 series and thought it looked stupid - too much gap in the wheel well. Not an issue if you're going to lower it or something - I have no such plans. I noticed the turn in was slightly (and I mean slightly) less sharp with the higher profile tires (we're only talking 0.22" higher). You'll get that with a taller tire. Might be able to sharpen it up a bit by moving the RSB forward a little. Otherwise it was difficult to make any other judgements on the tire - it's been pouring here all day.
Other differences - a softer ride, and you've effectively raised your final drive ratio from 3.82 to 3.76 resulting in 70 or so less RPM down the highway. Some say this will cause the car to be slower off the line - I say it's unnoticable, or at the very least splitting hairs.
Old Jan 16, 2001 | 06:23 AM
maxfreak_98's Avatar
Re: SP5000
I do concur! the Dunlop 5000's are a great tire whether it's wet or dry (don't know how they are in the snow). I also agree that the 50 series is going to show MORE fender gap than we already have with the stock springs. I have 225/55/16.
Old Jan 16, 2001 | 08:52 AM
black97max's Avatar
Thanks for all your responses. I am definatly going to go with the Dunlop sp5000's 225/55/16.
Old Jan 16, 2001 | 09:00 AM
Also, I ordered mine from Tirerack (around $90 each)and had the local Nissan dealer install and balance them ($60).
Good luck
Old Jan 16, 2001 | 11:43 AM
WizzaMax's Avatar
Any thoughts on a 205/55ZR15? I like the tire and think it would do just fine with spacing and all. Even though my car is lowered...it should work okay.
Opinions....????
Old Jan 16, 2001 | 12:29 PM
brubenstein's Avatar
On a 15" wheel, if your rim width is 7", the right size would be 225/60 15 to maintain the stock diameter.
Old Jan 16, 2001 | 08:41 PM
CustomMax
Hey before you buy from anywhere checkout, http://www.Victoriatire.com
I bought a new set of four tires for my 18 inch wheels at a great price.
Old Jan 16, 2001 | 08:57 PM
Ch12i5
bridgestones...
well i just got new tires and rims...225/55/16 and borbet type e's. really good combination. anyway, i think if you need another option for tires, go with the Bridgestone Potenza RE730s. they're a really great tire, check out the user ratings for them at tirerack.com. all 8's at least, and a 9 for dry traction. so if you don't have a snow problem, try going with those tires. they also have the coolest looking tread design ive seen!
(all of the users who reviewed this tire bascially have audi's and BMW M3s and stuff...so you can get a good perspective on how well the tire does with sports cars)
Old Jan 16, 2001 | 10:16 PM
enticiveblkmax's Avatar
doesnt a tire size of 225/55/16 change the overall diameter of the tire, and affect the odometer readings? ive read that to correctly plus size, our tire size for 16' se rims should be 225/50/16.
Old Jan 16, 2001 | 10:19 PM
brittb's Avatar
I put the Yokahama AVS 245-45-16 on my SE 16 inch
rims and love the way they handle. Of course, anything
was an improvement over the stock Toyo's...
BTW, it sure was fun watching the guys at Discount
Tire put the tires on! It only took them an hour
or so...
BB :-)
AndyXXL's Avatar
It does but just a little, you won't even notice it.
Old Jan 17, 2001 | 03:29 AM
CFster's Avatar
Tire Size
In fact the difference in height going from 215/55r16 to 225/55r16 is less than going from 215/55r16 to 225/50r16.
P225/50r16 vs P215/55r16
Sidewall height: -0.23"
Overall height: -0.45"
Circumference: -1.42"
P225/55r16 vs P215/55r16
Sidewall height: +0.22"
Overall height: +0.43"
Circumference: +1.36"
The overall height on the 55 is slightly higher but that's just splitting hairs.
It looks a hell of a lot better too.
Old Jan 17, 2001 | 03:39 AM
CFster's Avatar
Also..
The degree of speedometer error going to the 50 series is higher:
P215/55r16 to P225/50r16 at 55 mph will now read 56 mph.
P215/55r16 to P225/55r16 at 55 mph will now read 54.07 mph.
Difference at approx. 80 mph in rpm (5spd) 3.82 rear end:
P215/55r16 to P225/50r16 3200 rpm is now 3258 rpm, 58 more
P215/55r16 to P225/55r16 3200 rpm is now 3146 rpm, 54 less
Miket2006
Mar 1, 2021 03:55 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Garrettz459
Sep 28, 2015 02:50 PM
